Alpair 10.2 in 8 liter sealed - Too good to be true?
Old 6th October 2012, 12:18 AM   #41
cotdt is offline cotdt  United States
Send a message via AIM to cotdt
I put the Alpair 10.2's in 8L sealed enclosures and was surprised by the bass extension for a 5.5".
The frequency response without any crossover components is as flat as I've ever seen for a fullrange, thanks to the built-in BSC. That said, the 8kHz and 10kHz breakup peaks were not seen in the official datasheets, and the Fs is 40Hz (after break-in) and not the advertized 36Hz. Since the other official T-S parameters are off as well, the box calculations still end up the same.
Harmonic distortion I measured to be very low. It sounds good, very good. Upper midrange clarity would be improved if crossed over to a tweeter at 2.2kHz LR2. To me, everything sounds better with a tweeter.
Old 6th October 2012, 12:58 AM   #42
I must say that built-in BSC is pure genius. It makes it soooo easy (and cheap) to make a quality speaker. So simple.
Old 6th October 2012, 01:39 AM   #43
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Originally Posted by cotdt View Post
I... and the Fs is 40Hz (after break-in) and not the advertized 36Hz. Since the other official T-S parameters are off as well, the box calculations still end up the same.
Your have to remember that T/S parameters are curves notscalars. Typically us DIYers ar emeasuring in quite a different spot on the curves. That your numbers are soclose to the factory ismore an indication of how horizontal the MA T/S curves are --backed up by other's measures.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 6th October 2012, 03:25 AM   #44
rongon is offline rongon  United States
rongon's Avatar
Thanks! That is great info. I got some proper sized baffles cut, got a compass to draw the outlines for the circular holes. Now I just need to cut the holes, glue the two layers of the baffle together (to form the rebate for flush mounting the drivers) and glue them to my old B&W boxes. Maybe this weekend I'll do it...
But you've given me more reason to get to it. Thanks again for the data.
Old 6th October 2012, 10:45 PM   #45
dave
Really? I see. I had always thought that factory specs were computer generated and not measured, due to them always being different from actual measurements.
Old 6th October 2012, 11:29 PM   #46
frugal-phile(tm)
planet10's Avatar
Factory numbers are typically an average from a significant sample (Mark measures something like 8%) using LEAP or LMS. Tight drivers like Mark's will be +/-8-12%, Fostex as high as 18%, less tightly controlled, you take a guess.
More than once i have posted my measures of an FE127 -- far from factory -- and then Mark measured them with factory kit and got numbers essentially the same as factory. Fs of 75 vrs over 90 IIRC.Both sets of measures eqully valid.
dave
Old 10th October 2012, 02:36 AM   #47
JR_W is offline JR_W  United States
I have a pair of Alpair 10.2s breaking in, running them hooked up to my chip amp PC amp while sitting in their cardboard boxes.
Sound great, all things considered. One seems to be a little more sensitive than the other, I'll give them a few days of low power jazz to loosen them up.
Old 11th October 2012, 12:06 AM   #48
After just 24 hours the difference is pretty stark, they really loosened up a lot in just a day. Not much bass sitting in a cardboard box, but man the detail and imaging is right on up there. And they have evened up, I thought they probably would.
I'll build some of these small boxes to run them and probably do a Pensile or whatever that large TL box is for these over the winter.
Old 11th October 2012, 12:28 AM   #49
markaudio is offline markaudio  Hong Kong
markaudio's Avatar
Hi Guys,
Emil Askov in Europe has sent me details of his home built Alp10 small enclosure project using IKEA bowls (see pics). These bowls appear to be increasingly popular for smaller projects. I've not had any opportunity to listen to spheres, would be interesting to know if any members have any experience with smaller size projects like Emil's.
Cheers
Mark.
Old 11th October 2012, 01:52 PM   #50
Nikola Krivorov is offline Nikola Krivorov  Bulgaria
Looks fantastic this Ikea sphere Is that the big one, the 28cm bowl? In that case the total volume should be about 15L, how is that for a sealed enclosure?
Alpair 10.2 in 8 liter sealed - Too good to be true?Hide this!Advertise here!
Alpair 12 vs Alpair 10.2 and a little Fostex 166 germpod Full Range 4 28th January 2011 03:19 PM
Alpair 10 wide bass driver and Alpair 10 Fullrange _henry_ Full Range 71 15th March 2009 11:37 AM
Fostex 126e response (10,5 liter BR) Juspur Full Range 0 2nd February 2005 07:18 PM
good sealed box size for a 10" Peerless XLS sub peerless Multi-Way 1 1st August 2003 09:01 PM
Copyright ©1999-2017 diyAudio
