#11 | |
frugal-phile(tm)
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#12 |
Fir, eh? Hmmm... That's different. Fir would be a softwood, like spruce, pine, etc?
I got my Alpair 10.2's today. They're a bigger driver than I imagined. Very impressive. Can't wait to hear 'em. I have a pair of old B&W DM100 8.5 liter cabinets. I'll be happy to use them as a start, especially since I can't afford $200 for a pair of cabinets at the moment. The B&W cabs are made of 14mm (approx 1/2") particle board. Not very beefy, no. Would it be useful to clamp and glue an additional 1/2" MDF board on the front, as an additional layer of baffle? I have several project panels of 1/2" MDF from Home Depot, left over from making some shelves. I was thinking of making sandwich baffles out of the MDF. I could cut the 139mm mounting hole in the first 1/2" baffle layer, with the driver front mounted on that. Then, I could make a second baffle layer, firmly glued to the first layer. In that second layer, I'd cut the 165mm hole to fit around the 139mm diameter hole, and around the driver mounting ring. I see in the drawing that the driver mounting ring + basket total depth is 13/32". I wouldn't get away with another 1/2" MDF layer, would I? I could check to see if I can get a 3/8" thick sheet of birch ply, or maybe MDF. So in the end, I'd have three 1/2" layers for the baffle, the original cabinet, the first 1/2" added baffle layer, and the second 1/2" added baffle layer. Would it be better to have a constrained layer of damping in between two of the baffle layers? It doesn't seem too difficult, even for me. It's the joinery that would cause me trouble. But I'm sure there's something I'm missing, because it seems there always is. OK, what am I missing? Thanks... -- |
#13 | |
frugal-phile(tm)
dave
#14 |
Douglas fir is pine, upgraded.
#15 |
Fir is significantly upgraded compared to the commonly available pine.
I was so much older then, I'm younger than that now. |
#16 |
No botanists in this thread, I see.
Fir and pine are both members of the pine family pinaceae, but different genera. Fir is abies, pine is pinus. Douglas-fir is a crazy one. Its genus is pseudotsuga (false hemlock) and it's actually a member of the larch subfamily (Laricoideae)! Douglas-fir is not a member of the abies (fir) genus at all. The common name is totally misleading. Common names are confusing enough, but I love how the lumber industry made up names for species that don't exist. For instance, Yellow Pine. What is that? Actually, it can be Black, Jack, Jersey, Longleaf, Loblolly, North Carolina, Oldfield, Slash, Shortleaf, or Virginia Pine. It basically means that it isn't Eastern white pine (pinus strobus). Sorry for the thread drift... and that was a doozie. But my surprise was at why a softwood would be preferable to birch ply. -- |
#17 |
Ron; unsolicited pedantry at DIY Audio? That's new. I think the suggestion of D Fir was to specifically take advantage of its softness to provide a mechanical impedance at each of the two changes of materials
you don't really believe everything you think, do you? community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi |
#18 |
Of course, softwood doesn't necessarily mean 'soft' either. I well remember GM discussing some boxes he made a few years back from pine that had spent the best part of 150 years seasoning as part of a barn in Georgia. Stiffness-weight ratio was extremely high; apparantly getting on for aluminium / sheet metal levels from its resonant behaviour.
#19 | |
<chuckle>
No? |
#20 |
MDF is hard?
| Alpair 12 vs Alpair 10.2 and a little Fostex 166 | germpod | Full Range | 4 | 28th January 2011 03:19 PM |
| Alpair 10 Bass + Alpair 5 - Woodwill Japan | markaudio | Markaudio | 16 | 26th January 2010 11:48 AM |
| Alpair 10 wide bass driver and Alpair 10 Fullrange | _henry_ | Full Range | 71 | 15th March 2009 11:37 AM |
| Fostex 126e response (10,5 liter BR) | Juspur | Full Range | 0 | 2nd February 2005 07:18 PM |
| good sealed box size for a 10" Peerless XLS sub | peerless | Multi-Way | 1 | 1st August 2003 09:01 PM |
