What Amp do you use with your Mark Audio Drivers? - Page 19 - diyAudio
Old 7th May 2014, 02:11 PM   #181
carl68 is offline carl68  Sweden
Raysonic sp-120
Old 10th July 2014, 03:01 PM   #182
The Elekit with the stock 2A3 had too much gain I had to increase the NFB because it was resonating at female voices. Now sounds great and it's still loud at 12 o'clock and its clipping at 2 o'clock. I'm looking for a pair of 300B before I make additional changes I believe they can use the additional gain just fine. Any recommendations before I spend $$$.
Old 10th July 2014, 05:46 PM   #183
chrisb is offline chrisb  Canada
Shuguang Treasure - not an entry level price for 300Bs, but if my experience with the 6CA7s was any indication, it'd not be money wasted
I also had great results with EH Gold grids
what are the driver tubes?
... so, not as easy at it sounds, this letting go thing
Old 10th July 2014, 05:56 PM   #184
I'm using Sylvania 6SN7WGT Great driver tubes good extended the low end. For 300B I was considering the Svetlana 300B but are around $300 also, Psvane 300b T II but again over $300 for a pair!
Old 11th July 2014, 10:23 PM   #185
StevenZ is offline StevenZ  United States
Currently I use a D-Sonic M3-800S. Although, I have ordered a 300B integrated amplifier from Twin Audio and will be awaiting it's arrival in the next 2-3 months while it's produced and shipped. I'm looking forward to hearing my Mark Audio speakers with a quality 300B amp. Should be awesome.
Old 12th July 2014, 02:04 AM   #186
markaudio's Avatar
Hi Guys,
I've been getting excellent results with a slightly modified BR box design originally from Dr. Scott. Its height (O/D) has been shortened from 403mm to 370mm. I'm currently using a 300B SET, Accuphase DP65 CD player, Mac Mini - ITunes for sources (see pics).
Excellent large (if slightly soft) bass from the port @ 160mm, quite wide LF responses considering its a port. I'm finding the smaller internal volume suits my tastes from the original larger box, but bear in mind this is personal listening preference.
Scott also mentioned to me that a 12litre box using a 35mm port around 110mm long could produce a pleasing alignment. Good thing about simple BR's is they're easy to make and affordable. I'll make a few more during the months ahead.
I'll be using my 6V6 next week to compare.
Mark.
Old 12th July 2014, 03:52 AM   #187
doorman is offline doorman  Canada
doorman's Avatar
Anybody know if the above drivers are the 10.3's ?
It's great that such a "simple" enclosure can produce such satisfying results.
Old 12th July 2014, 04:11 AM   #188
vinylkid58's Avatar
Scotts bookshelf design is for A10.3/A10P, so we'll have to assume it's a 10.3, unless Mark says otherwise.
http://wodendesign.com/downloads/sim...lan-100214.pdf
jeff
Old 12th July 2014, 04:15 AM   #189
doorman's Avatar
jeff
Thanks !
Old 12th July 2014, 05:14 AM   #190
markaudio's Avatar
Yes, 10M G3's with modded coils. Trying them out. Will have the 10P BR cabs later in the month.
Cheers
Mark.
Pensil Series for Mark Audio Drivers planet10 Planet 10 hifi 49 22nd November 2015 11:08 AM
Mark audio I am looking at two of your drivers help please. phil09 Full Range 14 11th June 2011 03:09 AM
Mark audio drivers in ipod dock joe58 The Lounge 5 16th March 2011 02:55 PM
X_lin for Mark Audio drivers? rpnfan Full Range 3 26th October 2010 09:57 PM
Mark Audio Drivers are on Sale!! mdikovics Full Range 24 7th July 2009 07:11 PM
Copyright 1999-2017 diyAudio
