What Amp do you use with your Mark Audio Drivers?
Old 18th January 2012, 02:38 AM   #21
CabinetMakerRyan is offline CabinetMakerRyan  United States
CabinetMakerRyan's Avatar
Originally Posted by Bob Brines View Post
I am running my 10.2's of a Dayton DTA-100. Sounds great. Huge bottom end.
Bob
Looks like a cool amp for the 10.2's. Do you use the stock power supply?
Old 18th January 2012, 02:58 AM   #22
Bob Brines is offline Bob Brines  United States
Bob Brines's Avatar
Yes. It is 24v/5a. Should be plenty for the 30w/ch@8Ω for 0.1%thd the amp puts out.
Bob
Old 18th January 2012, 10:54 PM   #23
naturallmystic is offline naturallmystic  United States
I am using a tubes4hifi ST70 kit with Markaudio 10.2 drivers. What Dave (planet10) says is true. I am sorry to say I don't like this combination very much. SImply put something is missing and it isn't the Markaudio 10.2s fault.
I have also been using the 10.2 with an Elekit TU-879S Stereo Tube Amplifier Kit that put out about 8.5 watts. It sounds wonderful.
In the end I think my ears just prefer single ended sound. That's my 2 cents.
Old 19th January 2012, 02:34 AM   #24
wcwc is offline wcwc  United States
I may try a tube amp in the future, but for now I will use either an 20 yr old Denon receiver or a 1611 AVR for the Pensil 12. I may build a MarKen 10.2 sooner to replace some Baby Advent IIs in my shop and see how I like the sound of a single driver speaker. I will use a 20yr old Yamaha Integrated or a Marantz AVR to power it.
Old 19th January 2012, 05:09 AM   #25
OlavHaal is offline OlavHaal  Norway
OlavHaal's Avatar
Default amps Mark Audio Drivers...
Hi all!
First run my Alpair10.2 on an integrated Harman/Kardon 980. Just about 90% perfect. Then I built a SDS-254 ClassD Kit which is a powerAmp. Using the pre-out in the Harman and the sound is even better...
Now building a B1 Buffer(soon to be finished) - maybe even better???
And I have aquired the 2SK82(KD33) to later build the LĀmp - to see if my chain ending with the Fonken-like Alp10.2 can follow till the end.
Or else I will have to build some new MA-released drivers......or maybe CSS new drivers....
Best 2 all!
Olav
Old 19th January 2012, 07:06 AM   #26
markaudio is offline markaudio  Hong Kong
markaudio's Avatar
Hi guys,
I've just returned to from New Zealand out-back to a location where I can pickup broadband, flying back to Hong Kong this weekend. Found some beautiful hard woods for cabinet making but more about this when I'm back home.
Re amps, I'm running most Alpair 10's and 12's on Tony Wong's SET 300B + upgraded transformers from Kenneith Wong in the studio and a brother SET 300b at home: Tony's 300B (standard model)
Smaller Alpairs (depending on my mood) and CHR Gen.3 and CHP Gen. 2 on: 6V6 push pull integrated amplifier
Alpair 6's (mostly 6P's) on Derek Shek's Miniwatts (yummy): http://www.miniwatt.com.hk/
Also in the studio is an Accuphase: http://www.accuphase.com/cat/e-308_e.pdf
Source in the studio is: http://www.accuphase.com/cat/dp-67_e.pdf
Source at home is: http://www.accuphase.com/cat/dp-65en.pdf
Very interesting to read about the gear members are using.
Cheers
Mark.
Old 19th January 2012, 08:58 AM   #27
nicoch58 is offline nicoch58  Europe
Hi Mark interesting discussion.. I hope question too...
in a case of two way OB,ie 15" under with plate amp 150hz xo,how change the perceive dinamics ? ie can sound a lot bigger then the mere real db ?
Old 19th January 2012, 04:59 PM   #28
chrisb is offline chrisb
as I mentioned earlier, there are numerous aftermarket mods/circuits for the ST70 that might well transform the underwhelming performance you're now experiencing - Dave's own reference amp started out life as a pair of sacked out ST70s, and was rebuilt with this one:
Classic Valve Design - Dynaco Clone and Original Design Boards and Repair Kits - Dynaco ST-70 Modifications
This is the only tube amp I've heard with any Dyna content, and by all accounts any resemblance to the original is entirely in name only.
like my mind, this space intentionally blank
Old 19th January 2012, 05:45 PM   #29
buzzforb is offline buzzforb  United States
buzzforb's Avatar
With evry solid state amp I have thrown at the MA drivers I have used, (AlpehJ, F5, BA3) they tend to be deep and wide with their soundstage. The only amp that has pushed the musci out towards me is my brothers KT88 PP in triode mode. Only cavest is listening position. In my room, I am basically against the wall and can pull the speakers out as much as 5ft. In the instance, the soundstage is as deep as it would be in a proper venue. sounds clear and dynamic with good speration and imaging. The 7.3 beats the 10.2 in clarity and seperation. Tone on both is very good with 7 beating the 10.2. In my brothers room listening to Pensils with speakers out 4-5 ft and the chair in the middle of the room with 5-6 ft behind it, i get a lot more of the in your face sound. Whether this is his tube amp or the room setup will be determined this weekend. I will be taking my whole rig to his house to see. Side note; If i move my chair away from the back wall a distance equal to that of the speakers from the opposing wall, The soundstage moves out somewhat. I say all this to point out the many different factors involved in musical reproduction.
Old 19th January 2012, 06:20 PM   #30
andb is offline andb  Czech Republic
You've misconstrued what Dave said. His st70 comment was about the original, now quite old design. The if the amp you have is one of Bob Latino's kits, I'm pretty sure the only thing is has in common with the original st70 is the chassis layout...
I mention this because I use a Triode Electronics st-70 kit with my alp7.2's. I originally had some JJ tubes and it was ok, but I wouldn't say it was noticeably better than my old NAD705. I swapped in some NOS Tesla (EF806S & ECC802S) and Siemens (EL34) tubes. Its a totally different amp. So before you give up on your "st70 clone" try some tube swapping, maybe try replacing certain key capacitors, like the coupling caps.
In the summer when I don't want to heat the room, I use a BrianGT PCB based 3875 chipamp. Nice, but prefer the tubes.
What Amp do you use with your Mark Audio Drivers?Hide this!Advertise here!
Pensil Series for Mark Audio Drivers planet10 Planet 10 hifi 49 22nd November 2015 10:08 AM
Mark audio I am looking at two of your drivers help please. phil09 Full Range 14 11th June 2011 02:09 AM
Mark audio drivers in ipod dock joe58 The Lounge 5 16th March 2011 01:55 PM
X_lin for Mark Audio drivers? rpnfan Full Range 3 26th October 2010 08:57 PM
Mark Audio Drivers are on Sale!! mdikovics Full Range 24 7th July 2009 06:11 PM
