What Amp do you use with your Mark Audio Drivers?
Old 8th February 2017, 06:44 PM   #261
chrisb is offline chrisb
Quite stalling and just buy something for a change. I understand SH has the Audio Note M10 line stage on hand - don't worry, Janice would say "go ahead hon - you deserve it"
like my mind, this space intentionally blank
Old 8th February 2017, 09:40 PM   #262
vinylkid58 is online now vinylkid58  Canada
vinylkid58's Avatar
My truck needs new tires, a rear brake job, and a tune up.
jeff
Old 8th February 2017, 09:49 PM   #263
Old 9th February 2017, 03:11 PM   #264
bhpistorqintorpm is offline bhpistorqintorpm  India
DIY Jean Hiraga driving Alpair 10.3M fixed in their own packaging card board box .. will be getting BR Stand Mount cabinet made for them shortly!
-Som
BHP=Torque X RPM : yeah i know, stuck to my automotive forum handle
Old 16th April 2018, 06:58 PM   #265
Destroyer OS is offline Destroyer OS  United States
Destroyer OS's Avatar
Originally Posted by xrk971 View Post
I may be minority here but I am powering my A7.3 on a wall mounted MLTL with a very low cost but great sounding class AB TDA7297. $5 amp but sounds fantastic.
I'm using my Folsom DIY7297 with some CHP-70's I got off Craigslists in some pretty decent plywood boxes. I'm taking advantage of boundary reinforcement a little for bass. But overall it's a very nice match. The little MA's are very articulate with it. Right now I'm listening to Caribou, which is electronica, and I'm not disappointed with the bass. No it's not big heart throbbing, ground pounding, but it is still very pleasurable. To be honest, most the time I don't want to have super-blasting bass anyways. In contrast an FE126en flops on it's face and make like zero bass with the amp, even in a compression loaded back horn...
The one comforting factor is that peaks of 24w aren't going to ever crinkle the drivers.
Old 16th April 2018, 07:08 PM   #266
toobhed is offline toobhed  United States
At the risk of repeating what others may have replied: The Pass designed Amp Camp Amp. I use the original version to power MA Alpair 12P Pensils for a great result, also use it on my MA Alpair 10P in a Brine's BR bookshelf cab.
I'm waiting with baited breath to buy the new version of ACA when it comes back in stock.
Mario
Old 16th April 2018, 07:19 PM   #267
I am a bit curious about the ACA, but I've had probably half a dozen people tell me they like my 7297 more than it, and several over the F5 (or swap it out during summer). That has basically prevented me from building up either.
Old 17th April 2018, 12:26 AM   #268
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
Try the Alpha 20. Easy to build and operate adjustment feee Class A amp by Aksa. No unobtanium parts (all low-cost in stock parts on Mouser/Digikey) and it sounds fantastic. Circa 0mV DC offset from cold to hot - not a pot to adjust. Bias is rock stable courtesy Pass Aleph CCs. UMS compliant and uses any standard Pass Fx series PSU. Early Proto has pot but not needed will replace with fixed resistor in subsequent ones.
Aksa Lender P-mos Hybrid Aleph (ALPHA) Amplifier
30dB gain so doesn’t need a Preamp to reach clipping from a basic source.
Here is FFT for 1w into 8ohms:
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 17th April 2018, 12:39 AM   #269
That does look like a nice project alternative. Although, it is no less of a heater.
Old 17th April 2018, 02:42 PM   #270
hoyungh is offline hoyungh
X that amplifier looks good but I have a few worries.
1. i live in the tropics average temp 30-35C in the afternoon so wont the amp sort of make my room hotter?
2. dont speakers sort of have distortion around 1%. would 0.017% be overkill or are we measuring the wrong thing since i think you mentioned that these amps represented a jump in performance
thank you for your contributions in these columns
What Amp do you use with your Mark Audio Drivers?Hide this!Advertise here!
Pensil Series for Mark Audio Drivers planet10 Planet 10 hifi 49 22nd November 2015 10:08 AM
Mark audio I am looking at two of your drivers help please. phil09 Full Range 14 11th June 2011 02:09 AM
Mark audio drivers in ipod dock joe58 The Lounge 5 16th March 2011 01:55 PM
X_lin for Mark Audio drivers? rpnfan Full Range 3 26th October 2010 08:57 PM
Mark Audio Drivers are on Sale!! mdikovics Full Range 24 7th July 2009 06:11 PM
