I have bought a pair of Audio Nirvana Standard 8 drivers and a pair of Bicor 250 back loaded horn cabinets. The horns were intended for Lowther drivers, but they are told to work well with AN as well. They do, but are lacking in the bass range. The tiny Dayton Needles I built have much, much more bass than these huge speakers
IMG_0754.jpg IMG_0757.jpg Commonsense audio advises to use the AN's in bass reflex enclosures. Since I don't have a large house and the WAF of the huge horn cabinets is very low, I want to build a pair of new enclosures for these drivers. I very much like the design of the 'Solo 103'. Would such a design with openings in top and bottom of the baffle be possible for an 8 inch fullrange driver? And could anybody with experience and design software help me? Solo 103: Solo 103.jpg |
#2 | |
This format of multiple high aspect ratio slot ports can certainly work well (I've built a fair number along these lines over the past few years, with drivers up to 6.5" ) On taller enclosures, the port slots might end up configured along the sides, Fostex FE167E / Fonken : ![]() or alternatively in an MLTL, as single slot at the bottom. Mark Audio Alpair 12 SuperPensil ![]() If the manufacturer's published T/S parameters can be trusted, or if you have real world measures for your exact pair, there are folks here that'd likely be happy to calculate a design that could work better than the Bicors or a bog stock BR enclosure. It might seem obvious that simply "adapting" a design proven to work for another driver to fit a different model / size of driver or for room/dimension constraints could be a wasted exercise - but things that "go without saying" , well, ask your wife about "I thought that was understood"
you don't really believe everything you think, do you? community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi |
#3 |
Thanks for the quick reply!
Is it technically to have the slots on the sides or high and low in the baffle like the Solo 103? I'd really like to make the cabinets as narrow as possible, with the drivers in the middle, with one slot above and one slot below the driver. Although this looks quite good as well: http://homepage.mac.com/tlinespeaker...Ken12-comp.jpg The specifications of the drivers can be found here |
#4 |
frugal-phile(tm)
That last bit is a contradition since the purpose of the horn is to bring the bass.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#5 |
No kidding, and going BR for the AN8's isn't going to get you any real bass either.
jeff |
#6 | ||
If a slot ported enclosure is deemed to be acceptable, you can feel free to locate them where ever you like, except on rear if close to wall. Keep in mind that very narrow enclosures may need some degree of BSC - either active EQ before the amp, or with passive components at speaker level. Quote:
#7 |
Sachiko, Vulcan?
If those can't deliver bass in a narrow profile enclosure, what would?
#8 |
#9 |
If you can get "real" bass from AN8s i'll be very interested.
Mine have been in three different cabinets so far. None of which produced satisfying bass, to my taste. They are now in OBs, and this is where they shine in my opinion. But they need the help of some 15" drivers as well. I still believe they are worth buying though. |
#10 |
| :) Check my first Bass Reflex 6 ports, 2 driver standard configuration design :) | endrek | Subwoofers | 31 | 11th April 2011 05:37 PM |
| Bass Reflex | Guss | Multi-Way | 1 | 15th December 2003 02:33 AM |
| Bass Reflex (How it works?) | gchrist | Multi-Way | 1 | 11th November 2003 11:21 AM |
| Bass reflex enclosure | Opie | Subwoofers | 5 | 5th January 2002 01:36 AM |
| bass reflex? | GAK | Multi-Way | 2 | 23rd October 2001 03:04 AM |
| Page generated in 0.13212 seconds (81.81% PHP - 18.19% MySQL) with 11 queries |
