Hi i am new in full range driver and this is my very first post in this forum.What will happen if I build Sachiko with 17' of depth ( original design is 18')
This is my first back loaded horn project, I make a mistake when I cut the side penal, I am totally noob......pls help! |
#2 |
It could sound even better
#3 |
You have options,
1. re-cycle the side panels and cut some new ones. 2. if you're cuts are accurate add a 1" piece with biscuits or something, I think it will be OK if you just glue and clamp as well. 3. Make the back panel wider and sit the sides on it, you'll still be short 1/4" but you could just add a 1/4" shim. I don't know how critical the internal measurements are, I suspect you need to be pretty accurate, some one will know. |
#4 |
I reduce 1' for penal a,c,d,e,h the internal diamention is maintain, but the horn length probably 6'-7' short than the original design.
The enclosure is almost done, I really worry about the sound... |
#5 |
I should continue the project or give up then build a new one?
#6 |
If the enclosure is nearly done, finish it, you never know.
#7 |
Tq, Thomas .
| Sachiko dual horn cabinets. Anyone tried them? | diyninja | Full Range | 40 | 18th May 2011 08:09 PM |
| Will the Tangband W8-1772 work in a Sachiko double horn | zobsky | Full Range | 63 | 27th August 2010 09:41 PM |
| Frugal-Horns Sachiko 8" horn speaker - Nasty dips in frequency response | jmillerdoc | Full Range | 117 | 4th June 2010 04:23 PM |
| horn building help | boptura | Multi-Way | 0 | 11th September 2008 03:21 PM |
| Page generated in 0.08755 seconds (77.01% PHP - 22.99% MySQL) with 10 queries |
