Hi I and making a pair of TB w3 871sc Needles, I will use a Gain clone amplifier lm3886.
Do you think that I need a notch filter fot the TBs? How could I make this notch filter? Thanks in advance |
#2 |
just another
Hi I don't know the speaker you are mentioning, but if you want to learn about notch filters I found this wikipedia page invaluable. It takes the guess work out of it!
RLC circuit - Wikipedia, the free encyclopedia go to the parallel RLC section (but it helps to read the preceding stuff as well. If you are like me and shy away from maths, it looks intimidating but you really only need the Q formula and the Wo formula to be able to work out a filter suitable for your desired frequency. Note that Wo is in radians, so you need to divide by 2pi to get Hz. (edit: the original formula I linked to was incorrect I've now fixed it, sorry for any confusion!) Swapping the values for C and L will change the q (without changing the centre frequency) and the resistor determines the amount of cut. Choose a value for C or L and the frequency and then work out what the value for the unknown component (L if you chose C) is. adjust until you get usable values and the desired Q. The higher the Q value the narrower the notch will be. I found this to be a much better starting point for simulation (very close to the desired frequency) than the methods I'd found in my speaker books. Tony. Last edited by wintermute; 14th January 2012 at 11:52 AM. Reason: change the formula as I linked to the wrong graphic, woops! |
| Notch Filter Design - Seas L21 (H0955) Breakup Modes:Single or Multiple Notch Filters | dtm1962 | Multi-Way | 10 | 8th February 2010 02:17 PM |
| Regarding Cyburg Needles - What Is A Notch Filter? | JimOfOakCreek | Full Range | 5 | 27th March 2008 11:44 AM |
| can i use needles? | ACQUA | Full Range | 3 | 23rd October 2006 02:22 PM |
| tubes n needles | silurato | Tubes / Valves | 6 | 22nd June 2005 05:03 AM |
| Linus 2 vs needles ? | Branwell | Multi-Way | 0 | 4th October 2003 01:36 AM |
| Page generated in 0.07749 seconds (65.96% PHP - 34.04% MySQL) with 10 queries |
