#11 |
Otherwise you could make rear access panel and rear mount the woofer. I'de hate to see you blow one up and not be able to change it.
#12 | |
of course that would change the air volume between drivers, which IIRC is important? anyone remember the Linn Sarah 9?
you don't really believe everything you think, do you? community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi |
#13 |
#14 |
I like the idea of using the NS6 isobarik for lows. They are efficient enough to play low without having to feed them lots of power.
#15 |
Cheap too!!
#16 |
Really cheap actually!
jeff |
#17 |
it is all sealed and glued inside. No service opening. I never blowed any speaker so there is litlle chance for it to happen. I didn't want any compromise to enclosure stiffness. Atleast they are so cheep it is not big deal to waste couple of drivers. But NS6 are so fantastic as isobarik. They give 4ohm and 88db sensitivity and great lows. I am realy suprised.
#18 |
That's why I think it's an excellent choice for isobarik. I hadn't thought of it before, but I might take a little inspiration from your design.
#19 | |
Couldn't find any dimensions or other details of construction, but given the implied depth from this photo, and the fact that the bass driver was KEF B200, I'd say not a whole helluva lot This also gives a good idea as how to go about retrofitting a mounting flange for the exterior driver if front panel already glued in place. These were a mofo to replace drivers - IIRC lots of goopy silicone type caulking - and of course, everything was "Linn Tight"
you don't really believe everything you think, do you? community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi Last edited by chrisb; 5th March 2012 at 07:47 PM. |
#20 | |
Well if either of the internal drivers blow, it won't be just the cost of the driver you're out. In the case of the Sarahs that I mentioned elsewhere, there was a certain class of user in the 80's hellbent on testing the limits of the system - and it seemed the smaller the enclosures, the greater the abuse. So maybe it won't be an issue for you, but I would never build any speaker that didn't allow service access to all active or passive components.
| Markaudio fullrange + Woofer 6 (FAST) | Crossblade | Markaudio | 22 | 9th September 2011 11:05 AM |
| looking for effecient 4" driver for FAST system | Josephjcole | Full Range | 24 | 13th April 2011 12:50 PM |
| FAST and SIMPLE driver for HEXFETS (linear use). | ontoaba | Solid State | 29 | 11th February 2011 12:19 AM |
| FullRange/FAST in a car door | 901Fixer | Full Range | 5 | 30th November 2010 04:04 AM |
| FYI: Hybrid MOSFET/Driver for Ultra-Fast Switching | RaiTulo | Class D | 0 | 17th July 2009 07:49 PM |
