When attempting to high pass a set of full range speakers, the math on a first order filter is quite easy. But what to choose for the "R"? Do I choose the nominal impedance of the speaker, lets say 8 ohms? Or do I use the "R" at the given frequency I am trying to cross at?
For example, if I am attempting to create a high pass filter at 80Hz for instance, most full range drivers at this particular frequency have an impedance of at least 50ohms. At 50 ohms, and with a crossover at 80Hz, I would need a 40uF cap. But if I use the nominal 8 Ohms in the calculation, I would need a 250uF cap. Which calculation would you use in designing? Of course I would probably get a few caps, and see what sounds best, but I am looking for the technical answer. Thanks |
#2 |
frugal-phile(tm)
I'd put the cap in front of the amplifier & use the input R of the amp.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#3 | |
you don't really believe everything you think, do you? community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi |
#4 |
Hello Anchan,
both won´t work acousticly good, without measurement, Impedance, it is very difficult. Better take a active sub with active sat crossover, 500 µF in best quality are more expensive.
http://www.hm-moreart.de |
#5 |
The problem with first order crossovers is that they take such a long time to get any significant attenuation that you can end up with peaks in the response corresponding to impedance peaks of the driver.
Have a read of the crossovers section of the articles on Rod Elliott's website. Chris |
#6 |
Very good method is to maintain first order but also use a shunt resistor to strongly reduce output gain at resonance. In my open baffles I cross to woofers at about 200hz. I'm using 90uF capacitor and additional 50ohm resistor beetween + and - of the fullranger (Sonido SFR175 Alnico). Works really great. IMHO no need for 2nd order filter.
#7 |
Thanks for the reminder. I've had some success on tweeters but I haven't checked it out on a FR.
#8 | |
Paul |
| Combine high pass tweeter with mids without low pass -Need help | lessNoise | Multi-Way | 2 | 3rd August 2011 10:34 AM |
| 1" full range high pass newbie question | troglodyte | Full Range | 15 | 26th April 2011 12:10 AM |
| To High Pass or Not High Pass?......What a Question! | mayhem13 | Multi-Way | 2 | 23rd November 2009 10:16 PM |
| DIY Low Pass and Mid/High Pass (Bass Blocking) Filters | runslikealpaca | Everything Else | 1 | 19th June 2009 10:59 PM |
| Question about power amp built in high pass filter | crippledchicken | Solid State | 0 | 22nd October 2008 06:09 PM |
| Page generated in 0.08263 seconds (84.26% PHP - 15.74% MySQL) with 10 queries |
