Old 3rd January 2012, 03:51 AM   #1
Default Aluminum cabinet? (FE206En) Need Advice
Hello everyone
This is my first thread. I have been searching this forum for a long time and joined recently. All i can say is i have learned so much and want to try everything
I have a tube amp kit coming to me tomorrow from Tubedepot.com (8LS) and want to make a set of full range monitors to pair with. The drivers i will use are the Fostex FE206En (from Commonsenseaudio.com). They look really nice and from what i have read, they preform very well. Bass is not a issue for me. I have subs for that
So onto my questions. I want to make a cabinet out of aluminum, i mean the entire thing. All the sides, bracing and ports etc.... Is this a bad idea? I don't see many speaker cabinets made out of aluminum. The cost is high and can be time consuming but i have the funds and time.
Would the resonance of the metal be an issue? Would i still put insulation inside the cabinet (i think it's called damping material)?
I am no expert when it comes to speaker design, crossovers or anything like that but a full range speaker doesn't seem to hard.
Over the years i have made many things at my shop. Customized this and customized that. Made enclosures for Class D amps, Gainclones and some tube amps. Also made tons of thing for my Emotiva gear. I can pretty much make anything. Some things take longer than others.
Here are some projects i've done in the past:
Click the image to open in full size. Click the image to open in full size.
Any suggestions or insights on my idea of making an aluminum cabinet would be wonderful
Old 3rd January 2012, 04:21 AM   #2
Richard Ellis's Avatar
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
Have you ever heard of the 'Minimus 7' ???? It was a metal (Aluminium?) enclosure loudspeaker of miniscule dimensions. It had a 4" driver and a dome tweeter. Perhaps it was one of the first metal "mini-speakers" on the market. Others of that era were the ADS brand metal speakers..among others. My guess is the metal used was Zinc rather than Aluminum, as they did not "want" to "ring" at all! The Minimus 7 did bring so-called mini-speakers onto the forefront of consumers......sold at Radio Shack stores, they were everywhere.
As you seem to have easy access to CNC machines, the world is your oyster for designs.......far beyond what has already been made.
Give us your thoughts............& we'll brainstorm on this.
__________________________________________________ _____Rick.........
Old 3rd January 2012, 04:37 AM   #3
picowallspeaker's Avatar
Hi , great jobs you've done !
The 'grooves' (sorry for the translation )onto the metal panel are very nice.
They can also take an active part in speaker construction , on the baffle to limit diffraction from the speaker to the panel , or at the (rounded) corners .
The depth and distance between them , and their width would determine which
frequency to cut..or delay
But the primary function of a cabinet is to isolate the front wave and the back wave produced from the speaker , and also to let only the membrane vibrate ;
so , with a little cabinet it's easy to do that , much more thinking is implied in making a larger ,for powerful speakers ,cabinet . A parallelepiped is easy also ,but the flat panels are likely to resonate , anytime .
Old 3rd January 2012, 04:39 AM   #4
Hi Rick,
I looked those speakers up online and believe they are casted out of aluminum (from what i read). Really small speakers. Good for a computer setup or surround speakers in a HT setup.
The dimensions of the cabinet (mine) will be around 15H" x 12W" x 12D". Thinking of using 1/2'' aluminum plate. Any smaller i think the ring effect would be prominent. But i have never done this before and there is not much online about this, so i could be wrong. Maybe 3/8" or 1/4" would be okay??
I would use plenty of damping material to help with resonance. Plus use stainless steel hardware. Don't know if steel hardware would effect the magnet on the driver but i will just use SS hardware.
The baffles would be easy to make and could be secured and located with pins and screws. The port could be square and exit the front of the cabinet on the bottom.
To top it off it could be anodized in black or any color i want.
Old 3rd January 2012, 05:25 AM   #5
frugal-phile(tm)
planet10's Avatar
For the kind of setup you are envisioning, a sealed box will likely work best. You'll also, at a guess, need to XO the subs up around 120 Hz of so.
These drivers (FExx6En) are not designed to be used in reflex or sealed enclosure but can be used in a small (usually sealed) enclosure XOed to a sub each. It has been done with FE126En, and FE166En, haven't seen sims for the FE206En but when i go downstairs i'll model it up. My guess is that your suggested enclosure could well be twice as big as needed.
Al is a good enclosure material, you want it strategically braced to get the ringing up high enuff that it won't get excited. 1/2" is way overkill, 1/4" is likely fine, especially if you bend it.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 3rd January 2012, 05:27 AM   #6
I always read that is no good having two equal sizes in a cabinet .
There is the Aural proportion which is around 1:1.5
About construction , if you are making a removable baffle , which might be useful for stuffing etc. , you should think also of how to pressurize it , and to make it one piece with the whole enclosure . Foam or neoprene .
BTW I replied to the post 'cos I was thinking of making an aluminum baffle , too . I was thinking only of a rectangle with a hole on it , and secured to a very inert wooden ( Mdf)cabinet .
Old 3rd January 2012, 06:06 AM   #7
dave
Dave,
Thanks for your input. I learned a lot from what you just said. Shows how much i know about speaker design Nothing!!!
What would be a good sized speaker? You said mine might be twice as big as it needs to be.
Also it will be so much easier to machine the plates and bracing to size than to bend them.
How important is it for the cab to be 100% air tight?
I have had thoughts on a open baffle design aswell. Wonder if that would be easier or hardier
Thanks guys
Old 3rd January 2012, 06:35 AM   #8
Perhaps 1/2" is too thick.........(Can that be possible?). I was thinking a spray-on adhesive rubber compound for the inside in addition to the bracing. A rough finish to adhere to....can't think of a substance right now. There is another Ratio for enclosure dimensions. It is the so-called Acoustic ratio, .7937-1-1.2599 It is suppose to be a mathematically "inert" ratio.......to minimize internal standing waves. It would be best to mount the driver on the 'smallest side' so the baffle-step is easiest to deal with. Run some simulations on baffle-step programs to see where it is best to mount the driver.
Some one inch radius edges I think would work fine.....A material for the front face for absorbing sound...to work the diffractions to the max. Once we get a volume for the enclosure, & you plug in the values for the baffle-step......the driver location often times winds up in the weirdest of places.
__________________________________________________ ____Rick.........
Old 3rd January 2012, 08:06 AM   #9
frugal-phile(tm)
planet10's Avatar
Looks like 206En might not be so well suited. A 5.5 litre net box will give you a butterworth rolloff with an F3 (XO point) of ~165 Hz
What kind of amp do you have?
dave
Old 3rd January 2012, 08:12 AM   #10
dave
I'll be using a tube amp that's 8 watts (8LS from Tubedepot.com). But I do have Class D, A/B, a few Lm3886's and few old AVR's.
Woden Design (Wessex ML-TL) Aluminum Cabinet ? tms325i Markaudio 2 16th September 2011 09:38 PM
Cabinet dimension advice awol66 Full Range 12 29th July 2011 03:31 AM
need advice regarding painting the cabinet eitanwaks Multi-Way 2 23rd November 2009 09:11 PM
Need advice on cabinet finishing (lacquer) alphaGeek Multi-Way 23 25th March 2003 05:24 PM
Page generated in 0.14521 seconds (80.87% PHP - 19.13% MySQL) with 11 queries
