full range system I NEED HELP
Old 2nd January 2012, 03:58 PM   #1
amozos is offline amozos  Spain
Default full range system I NEED HELP
I am thinking on the idea of a full range system for my living room.
My living room isnt big. I want it for music (dance and hip hop) and films,
I was going arround Cyburg needles TBw3-871 with a chipamp.
I saw it has a very good response but for lower frecuencys hasnt got a nice bass.
Could you recomend me some similar system?
Could I use the TBw3 needles with a subwofer?
Thanks in advance
Old 2nd January 2012, 04:13 PM   #2
NotWisely is offline NotWisely  United States
having just built these a few weeks ago, i can safely say you should use a sub for those types of use.
may want to think about some kind of crossover for the needles...just to keep them from extreme excursion at the listening levels you may require
Old 2nd January 2012, 05:10 PM   #3
chrisb is online now chrisb
To keep things safe and clean at dance party SP levels, you definitely should consider HP filtering this weight class of driver - XO at a higher frequency than is generally considered "sub" category - i.e. in the 200-300HZ range, and use multiple small (6-8") woofers.
When you say "films" does that mean an HT/Surround receiver will be employed? While these can greatly simplify set-up, even with the mains selected to "small", you could be limited to the available HP XO frequency (i.e likely no higher than 120-150), so proceed with caution. Unless you get silly with the volumes, you'll not likely damage the smaller drivers, but the distortion at party levels can get pretty obnoxious.
like my mind, this space intentionally blank
Old 3rd January 2012, 10:52 AM   #4
Default needles
Ok,
I think I will go ahead with the needles and a gain card, I dont really want it for partys but I like dance music and R&B
I will try with two chanel chipamp (lm3886) and both needles.
My question is, after doing it if the bass is to low, could I add a subwoofer?
Which one do you recomend me? I could still use the TB w3 needles or I need to crossover them to be used for high frecuencys?
Thanks in advance
Old 3rd January 2012, 04:22 PM   #5
Originally Posted by amozos View Post
Ok,
Thanks in advance
I'd be surprised if any driver this weight class (including my current favorites Fostex FF85WK and Alpair6P) couldn't benefit from HP filtering and addition of actively powered woofer(s) when used for applications other than nearfield computer monitors. Starting with 6 - 8" units available from folks like Partsexpress etc for under $100 (less shipping) to as much as you wanna spend - there are too many options to be comfortable making a specific recommendation, and I've only ever built them.
full range system I NEED HELPHide this!Advertise here!
Full-range speakers in a bi-amped system? majerjack Full Range 29 25th November 2011 12:46 PM
Full range speakers for desk system? yzriver Full Range 12 12th December 2009 07:11 AM
Full range design for bedroom system bigjppop Full Range 19 9th December 2009 01:04 PM
Technology Student Wanting To Build Full Range System morfius Full Range 46 12th September 2007 09:09 AM
