Happy New Year!
My uncle and I are planning to build a HT setup for his living room. I have an idea, but would appreciate some advice before we begin. The room is fairly large, around 5x7 meters with sloping ceilings - 2.7 meters high sidewalls and 4.7 meters to the sealing in the center. My idea is to build a 5.1 system with five channels, each with two Markaudio CHR-70.3s. The subwoofer I'm considering is a 2x8" tapped horn TH-SPUD clone. I'd like to wall mount all five channels, but I'm not sure what would be the best design for these speakers. Sealed boxes would be easier to build and also better looking IMO (smaller). With two CHR-70.3s paralleled in a 16 liter sealed box I get 87Hz F3 according to WinISD. If I roughly double the size and make it vented I can reach 40Hz F3. This leads me to the following questions:
By the way, I imagine the system will be powered by a 5 channel DIY class-D/T amp (probably Hypex or Hifimediy modules), and the subwoofer(s) will have it's own readymade power amp. Thanks for the help! |
#2 |
I think that sounds like a great setup and I think doing sealed all around is a great idea. Crossing over around 90hz or so would be great between the two. I personally prefer 80hz but don't know really how much of an audible difference it would make going to 90hz. Nice thing is that you can always experiment to find the best for your application. Also doing identical cabinets makes building them much easier and aesthetically would look cool as well
Scott |
#3 |
frugal-phile(tm)
Not much
But with room gain from wall mounting, actual response will likly be lower than simmed. dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#4 | |
If possible I'd like to run all five channels without low-pass filters, meaning that the only crossover will be in the subwoofer. |
#5 | |
The DSP /bass management in most typical HT receivers (and I would have presumed HT-PC setups) allow for much higher HP filtering to the mains and surrounds than 80-90 - often with different settings for each channel. When using even multiples of full-range drivers of this "weight class", I'd be inclined to set in the 100-120Hz range and gain as much excursion headroom as possible.
you don't really believe everything you think, do you? community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi |
#6 |
frugal-phile(tm)
Play. Let it auto setup and work from there.
dave
#7 |
My thoughts exactly. There's so much manipulation that can be done with the AVR that the standard 80hz crossover point at least gives you a starting point and from there you can experiment with what works best in your room with your gear and to your ear.
Scott |
#8 |
Thanks for the comments.
This will be my first HT build so I don't know a whole lot about AV receivers. However, I'd like to keep the cost of the project as low as possible and avoid having to purchase an advanced and expensive AV receiver with 'auto setup' features. My initial thought was to buy a cheap 5.1 decoder like this or this. Do you have recommendations for a good value surround decoder/preamp? Another option would be to forget about the multichannel power amp project and instead spend the money on a integrated AV receiver. What are your thoughts on this? |
#9 | |
Honestly, I'd go for a mainstream AV receiver - plug and play and silly good value for from under $400 to whatever you wanna spend - but note that none will include power amp for LF channel.
#10 |
I bought a blu-ray player with 7.1 analogue outputs and then built my own amps to go on the outputs. No receiver was needed and I still don't use one. It has been fun, potentially gives more flexibility and future upgrade options for ultimate quality, but it's a longer journey til you get something up and running and you have to do the set up manually. Unless you want all of that, I'd suggest an all-in-one solution is the way to go too.
Don't rule out a used AV receiver - may allow you to get a better quality unit. I agree with Chris - sub should be self-powered using an off-the-shelf plate amp.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig. |
| chr-70 vs. chp-70? | Sonogasm | Full Range | 10 | 26th November 2011 05:02 PM |
| New CHR-70 | markaudio | Markaudio | 68 | 3rd February 2011 01:44 PM |
| CHR-70, CHP-70, Alpair 7 Desktops - Japan | markaudio | Full Range | 4 | 1st February 2010 01:42 AM |
| F.A.S.T. Project: Tangband W3-315 vs. MARK AUDIO CHR-70, CSS EL-70 or Alpair | jockel77 | Full Range | 13 | 11th January 2010 11:20 PM |
| Page generated in 0.12630 seconds (83.87% PHP - 16.13% MySQL) with 11 queries |
