Old 1st January 2012, 02:09 PM   #1
Default Fostex Fe126en vs Aplair 7 in FH MK3
Hey all,
I just built a pair of Frugel Horn MK3's with the Fostex FE126en. While I like the sound through my 10watt SET amp, I noticed there seems to be a lot of peaks in the highs, and they roll off a bit.
I'm curious about the Alpair 7 gen3's. Compared to the Fostex FE126en, I like the fact that it has a flatter freq response, is reportably more detailed and extended highs. Is there any compromise trying this driver or the 126en? Is there a big difference in efficiency? I like the 93db with my 10watt set amp, and wouldn't want anything less, but I'm confused by Aplairs spec of "SPL of 86dB", its can't be that bad is it?!
Old 1st January 2012, 11:02 PM   #2
chrisb is offline chrisb  Canada
Originally Posted by croweproductions View Post
Hey all,
The Alpair's sensitivity rating is pretty accurate, so yes that makes it approx 6-7dB lower than the FE126En - but as you've noted it ( Alpair) also has far smoother FR at both ends, and particularly in terms of low end extension. That was a big concern for myself and a lot of other folks when first experimenting with any of Mark's drivers - no question a bit of leap of faith - but it only one listen.
If you keep your average SPLs under 90, the Alpairs do so many things very well in any enclosure (would it be risky to describe the 7.3 a more refined than the FE126En? ), and certainly in the FH3. A BLH can provide some gain in the bottom few octaves to drivers like the Fostex, but it won't do anything to increase any speakers' net overall efficiency - however you might be surprised how much 10W of decent power can deliver.
you don't really believe everything you think, do you?
community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi
Old 2nd January 2012, 01:58 AM   #3
frugal-phile(tm)
planet10's Avatar
You might well,
A7.3 measures out, on average, just over 85.5, FE126En just under 93. But when you are playing it doen't seem to be that high a delta.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
FS Fostex FE126En Pair ClefChef Swap Meet 0 2nd December 2011 04:28 PM
FOR SALE: Frugal Horns Mk3 with Fostex FE126En Toppsy Swap Meet 5 2nd August 2011 07:23 PM
Fostex FE126En cabinet ziocalepino Full Range 6 22nd May 2010 07:55 AM
Planet10's Fostex FE126eN... chops Full Range 59 7th February 2009 01:24 PM
Peavey FH-2 FH2 FH1 FH-1 Folded Horn info X-Ray plans please! Peavey MB1 MB-2 Multi-Way 0 6th February 2006 03:50 PM
Page generated in 0.07725 seconds (72.00% PHP - 28.00% MySQL) with 10 queries
