Old 1st January 2012, 01:19 AM   #1
chuck55 is offline chuck55  United States
Default Hey, look at this Jordan substitute driver !
The Seas W15LY001 is almost identical in specs to the Jordan JX92S
Differences I see:
1) From Zaph's measurements Jordan is lower in midrange distortion.
2) Seas lacks the extension over 10kHz. But the Jordan is so ragged, might as well use a supertweeter anyhow.
3) Seas does not have the 6 kHz breakup that the Jordan shows in Zaph's waterfall response.
Old 1st January 2012, 10:54 AM   #2
GDO is offline GDO  Spain
I am afraid that the Seas unit will be awfully lacking energy in the top octave, whereas the Jordan will provide a very usefull output over 10khz, even if not the cleanest around. But it will do the trick whike the Seas surely won't.
Btw, though some use supertweeters with JX92s, i think that there are two many issues in the polar response because the JX92s becomes quickly too directional, and worse in the case of the Seas.
If you are not satisfied by the top end of this driver, don't be whimp and forget about minimalist "helpers" which won't do their job: the best is to set an orthodox xover at about 3khz with a proper tweeter like J.Griffin does.
http://documents.jordan-usa.com/JX92SG2siDesignPak.pdf
Old 1st January 2012, 03:40 PM   #3
borispm is offline borispm  Hong Kong
borispm's Avatar
Send a message via MSN to borispm
Hi Chuck,
It seems that the Seas woofer is a pretty good driver indeed, yet I suspect the usability above 4 or 5kHz is pretty limited, especially when listening off axis. Minimalist X-O isn't really impossible, a 1st order X-O at 4kHz may do the trick, if you're crossing to a large soft dome tweeter with really low Fs and clean performance. Forget about "supper tweeters" though, because you'll need tweeters that can go really low.
You may want to take a look at this:
Diapason Italia
It's a larger W18, but the idea is more or less the same.
Old 1st January 2012, 05:20 PM   #4
zman01 is offline zman01  Bangladesh
Job for this tweeter?
http://www.hometheatershack.com/foru...ld25dx1128.pdf
Some pics also here:
VWR126X Mid Woofer and LD25X Silk Dome Tweeter Preliminary Info - Home Theater Forum and Systems - HomeTheaterShack.com
Old 1st January 2012, 11:09 PM   #5
chrisb is offline chrisb  Canada
There are very manufacturers with products in the same category as the Jordans (i.e. thin metal coned full range drivers) - Bandor and Mark Audio are the first two that come to mind, and comparable to the JX92? - well how about the Alpair 10.2 ?
you don't really believe everything you think, do you?
community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi
Old 2nd January 2012, 12:42 PM   #6
borispm's Avatar
Zman, that tweeter could probably work, but I would suggest larger domes, say 27mm to 29mm... Sacrifice a bit of off axis for lower fs.
Old 2nd January 2012, 02:47 PM   #7
This new XBL tweeter has FS of 830Hz and X-max that a lot of full-range drivers would be happy to brag about - Klippel of 1.85mm and limit of 3.1mm - would that not be low enough?
Old 2nd January 2012, 03:05 PM   #8
borispm's Avatar
I tend to think SEAS 27TDFC may do a better job.
The Fs or Xmax alone may not be the only indicator of the tweeter's usability in the low frequency range, at least on the paper the SEAS driver looks pretty good for the application.
Chris, I have absolutely no experience on the CSS tweeter so I can't really say too much about it. Yet I tend to think the lower the Fs the better for shallow crossover. A Fs of 830Hz isn't bad at all, but I would choose one with a lower Fs. The rated excursion capability is great, but I wonder if that's going to be useful for tweeters. Pretty sure it will start to lose "resolution" and sound "strained" when driven that hard.
Old 2nd January 2012, 03:06 PM   #9
borispm's Avatar
If you can employ multiple tweeters that may not be a problem, yet you'll have to deal with even more complicated problems.
Old 2nd January 2012, 04:09 PM   #10
Boris,
I am on Chrisb on this one. The specs on the CSS one look pretty extreme for a tweeter. I didn't know that tweeters had xmax worth mentioning , but hey I am not an expert. The SEAS one looks good too and Fs is very low no doubt.
New Jordan Driver J6T??? cOz Full Range 27 9th September 2007 01:51 AM
Jordan JXR6 driver array neil_kaye Full Range 1 21st September 2006 08:54 AM
Jordan driver sma Full Range 0 12th February 2004 12:07 PM
Old Jordan 2" driver FS woody Swap Meet 0 16th November 2002 01:15 PM
Jordan JX92S driver speaker design Gaber Multi-Way 25 23rd August 2002 08:01 AM
Page generated in 0.11664 seconds (76.82% PHP - 23.18% MySQL) with 10 queries
