Sensitive bookshelf speakers for Tripath
Old 8th January 2012, 04:26 AM   #21
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Originally Posted by KyleinCowichan View Post
Oh, I misunderstood! Monday 5:30 okay? Thanks Dave!
OK, i now have a deadline to get the drivers back in the boxes.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 9th January 2012, 05:14 AM   #22
talaerts is offline talaerts  Belgium
Allegro is an interesting compact design that appeared in the German Magazine Klang & Ton.
It uses the Ciare HX160 fullrange driver as a widerange unit coupled with a tweeter.
Link (in German):
http://www.lautsprechershop.de/hifi/allegro.htm
91db sensitivity is pretty ok for a 380 x 250 x 280 mm speaker
Old 9th January 2012, 12:24 PM   #23
Godzilla is offline Godzilla  United States
Godzilla's Avatar
Can the Ciare drivers be purchase in USA?
Old 10th January 2012, 08:14 AM   #25
dheming is offline dheming  United States
dheming's Avatar
You could clone the Decware DM944/945. 94dB 1w/1m, 4 ohm impedance and has pretty decent bass response. I owned the 944 for about two years and quite liked it on most music using a SS integrated amp.
Old 3rd February 2012, 04:23 PM   #26
kiteohoi is offline kiteohoi  Netherlands
Originally Posted by planet10 View Post
(...) FF165wk would be the most efficient in a bookshelf size(...)
5-9 litre reflex would be good. My boxes for these are under development or in beta.
dave
I think I'll order a pair of FF165WK. How far are your beta plans?
(And if not (?), which of the small Fonken plans would you recommend for them?)
Old 4th February 2012, 06:23 PM   #27
robtwickenham is offline robtwickenham  United Kingdom
Just a thought - I built a pair of bokkshelf/near field speakers from a design by your countryman, Henkjan. These used the Alpair 5 drivers in a transmission line. For 2" cones, these go load and low, and can easily be augmented with a small sub, if required.
Old 4th February 2012, 10:33 PM   #28
frugal-phile(tm)
planet10's Avatar
... for a box 5-7 litre you need FF125wk. I haven't figured out how small a box needed for FF165 ... likely on the order of 2x the volume
FF125 plans need just a tiny bit of work and they can be purchased. Betas turned out well, but pointed out some necessary fixes in the docs.
The large 165 box is at the beta stage
dave
Old 5th February 2012, 10:33 AM   #29
G is offline G  United States
G's Avatar
I find it curious that no one has mentioned the Tang band full range drivers. The 4" bamboo one is plenty efficient enough to be driven by 12 watts in a small to medium room and they are inexpensive. I believe that a 1.25 (liter/cubic foot?) transmission line cabinet would work but I may be remembering the wrong driver specs. Here is something to look at:
http://sketchup.google.com/3dwarehou...90962a403b469d
Gavin
Old 5th February 2012, 06:53 PM   #30
dave
Ahh, OK. And for the FF125wk, I use the FE127e mFonken 1v1 (milliFonken – 4.5 litre vented) or the FR125S miniOnken 1v0.1 plans, right?
Sensitive bookshelf speakers for TripathHide this!Advertise here!
Help to build Hi-Sensitive Hi-Power Speakers birdyman Multi-Way 13 1st November 2010 04:44 PM
Building sensitive speakers sifis_samos Multi-Way 13 24th June 2009 02:52 PM
Kit for sensitive bookshelf speakers? Dan Rotigel Multi-Way 1 26th July 2008 09:59 PM
very sensitive speakers NED 209 Full Range 7 15th January 2008 05:54 AM
Class A for sensitive speakers XELB Solid State 4 25th November 2005 06:25 PM
Copyright ©1999-2017 diyAudio
