Sonido SFR 175 enclosure problem
Old 24th December 2011, 11:01 AM   #1
mhgawel is offline mhgawel  Poland
mhgawel's Avatar
Default Sonido SFR 175 enclosure problem
Hello,
I bought Sonido SFR175 AlNiCo Textil speakers some time ago and finally I have enclosures for them. These are 175 HORN enclosures from Sonido design. There's a problem as carpenter moved the internal wall about 10mm (0.4in) to the front. It has changed horn parameters:
- compression chamber volume is now 11033,8cm3 (673.3 cu in) instead of 11336,4 cm3 (691.8 cu in) in design,
- chamber throat cross section area is 100cm2 (15.5 sq in) instead of 120,2 cm2 (18.63 sq in) in design.
How would these changes influence the speaker performance? Is it worth to use the enslosures or I can just throw them away and order new ones?
Speakers data and chart, Sonido design and drawing with changes are attached below.
Best regards,
mhgawel
175 HORN.pdf
SFR175 A textil.pdf
enclosure.pdf
Sonido SFR 175 enclosure problemHide this!Advertise here!
FS: SONIDO SFR-200 ALNICO BDP Swap Meet 9 5th April 2013 09:01 PM
Sonido BIB peterbrorsson Full Range 68 23rd January 2011 09:31 AM
SFR-200-8 Frontloaded Tractrix Horn ak4396 Full Range 0 25th September 2010 08:46 PM
new Sonido SWR200A-8 Zen Mod Full Range 67 26th November 2009 06:24 AM
UA 175 Urei 175 opacheco Tubes / Valves 1 3rd April 2009 11:32 AM
Copyright ©1999-2017 diyAudio
