My Frugel Horn Mk3 Build
Old 14th December 2011, 02:04 PM   #1
mythosofsmythos is offline mythosofsmythos  United Kingdom
Default My Frugel Horn Mk3 Build
Hi All,
I built some Frugel Horn Mk 3s about a month ago and I've finally got round to take some photos and post the results.
First things first. They sound amazing. I'm not a hi-fi buff, but to my untrained ears, when coupled with an old cambridge audio amp and cd player I liberated from a dusty corner in my uncle's garage, they produce the best quality recorded sound I've heard.
Second things second. This is my first DIY project. Ever. So I know the build isn't perfect! I'll share some lessons learned in my subsequent posts.
Lastly, thanks to the designers of the Frugel Horn. Thanks for sharing!
Click the image to open in full size.Click the image to open in full size.Click the image to open in full size.Click the image to open in full size.
Old 14th December 2011, 02:24 PM   #2
I chose to use 18mm hardwood ply for the build. I chose the 18mm over the 15mm as I wanted a chunkier pair of speakers. In hindsight, I would have gone for the 15mm, as the 15mm design's baffle covers the entire front face of the speakers. i.e. it covers the sides the top and the bottom when viewed from the front. This would make the finishing easier, particularly if your ply has holes in the layers.
An alternative of course is to make sure you get good quality ply. I think I was ripped off at the saw mill with poor quality ply that had holes in the layers. This meant I needed to use wood filler to get an even finish. However, it is hard to match the colours, and it is tough to sand once dried.
I used a non-gloss, clear wood varnish. 3 coats. The red tinges you can see on the baffles are from where I got too frisky with a belt sander and sanded through the top layer to a lower, darker layer of the ply.
Finally, when cutting the wood, make sure to use the appropriate plan: 18mm or 15mm. Stupidly, I made some cuts using the 15mm plan, but was lucky in that I just needed to trim them down to the correct 18mm dimensions. Had it been the other way, using 18mm plans to cut 15mm ply, I would of wasted a lot of wood.
Old 14th December 2011, 02:35 PM   #3
When gluing, I didn't have any clamps, so I just laid the sides on the floor, added glue to the side plates along marked lines, then put the baffle, back, interior, top and bottom in place (applying glue to them too). Wood glue immediately has enough stickyness to hold the boards in place and you have up to 10 minutes to adjust them until they are perfectly in place. After I was happy with their positions, I placed heavy paint posts flush to the sides to give some stability, then balanced heavy objects on the top. It worked a treat.
The reason the alignment didn't come out perfectly in the end result was due to me not being able to cut 5 degree edges to the ply. I used a plane to attempt it, but it wasn't a great result. Another factor, was that the baffle actually curves slightly. Another sign of poor quality ply perhaps. Anyway, I didn't have enough wood to change it.
Old 14th December 2011, 02:51 PM   #4
I used synthetic pillow stuffing and old carpet underlay for the baff. The underlay I glued in place using impact glue which worked well.
I used quite thick electrical cabling for the internal wiring. I think the diameter was about 2mm copper (can't remember exactly). Although I understand there is a direct relationship between the quality of the sound and the thickness of the wire, I would have used thinner wire in hindsight. The rigidity of the thick wire makes it awkward to solder in place.
A final few notes on soldering. Watch out for the speaker magnet! It seems obvious as I write this, but the soldering iron will be strongly attracted to the speaker magnet. Also, be carful when heating the driver contacts not to melt the soldered connection further along the circuit towards the speaker cone.
Old 14th December 2011, 03:19 PM   #5
doubtingthomas is offline doubtingthomas  United Kingdom
Congratulations, great for a first build and thanks for sharing your experience.
Old 14th December 2011, 03:24 PM   #6
chrisb is offline chrisb
for sure one of the advantages of the thinner single strand wire is much faster / easier soldering
Old 14th December 2011, 04:13 PM   #7
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
mythos,
I am enthused that you are happy with the sound, and that you tackled such a project as your 1st diy.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 14th December 2011, 05:12 PM   #8
while not every scratch or kit builder may be able or want to post photos, how about a roll call - I'd be curious as to how many pairs / models of drivers to date
Old 15th December 2011, 12:48 AM   #9
fastbike1 is offline fastbike1  United States
While I haven't started cutting wood yet, I do have the wood and drivers. The build starts as soon as I finish the current three way build (yes I'm a double agent). I plan to go with the CHR70.3s, but I will also try EL70s.
I was so much older then, I'm younger than that now.
Old 16th December 2011, 05:28 AM   #10
kristleifur is offline kristleifur  Iceland
Very useful info! Simply fun to read, too. Thank you!
My Frugel Horn Mk3 BuildHide this!Advertise here!
Frugel-Horn Mk3 Builds & Build Questions planet10 Full Range 1281 16th August 2017 04:48 PM
Frugel-Horn Mk3 planet10 Full Range 1588 10th August 2017 09:39 AM
Frugel-Horn Mk3 flat-paks planet10 Planet 10 hifi 524 4th August 2017 08:44 PM
Frugel-Horn Mk3 Picture Gallery chrisb Full Range 224 26th January 2017 06:09 PM
Frugel-Horn Mk3 Auditions planet10 Full Range 24 8th June 2012 07:18 PM
Copyright ©1999-2017 diyAudio
