Old 7th December 2011, 07:02 PM   #1
Default Visaton Line-Array with curved front
Hello out there
I like to introduce my new speaker based on Visaton Pentaton BB because I'm amazed by myself how gorgeous they sound. Very natural, accurate and holographic, more like a BIG magnetostatic or electrostatic system than a typical full-range system. I owned some very expensive speaker systems the last 20 years but this one beats them all -but costs are comparatively low.
Eight Visaton BG20 and two B200 per side in a curved front closed box. The two B200 are central and play full-range, the BG20 are cut off at higher freq. from 9500Hz down to 1600Hz, beginning middle to the outside. The radius of the curve is the distance to the listening area (here 5.5m ~18ft.) so all speaker are directed to the ears. The crossover is in a separate wooden box near the power amplifiers. Below approx. 160Hz the line-array is cut by a BSS FDS 336 and there are two horns like those from Klipsch per side (the line array got a delay of course). The next days there will be a sub driven by PD2450 Precision Devices to get frequency from 16-40Hz
It is really worth to experiment with this kind of arrangement
Old 7th December 2011, 07:22 PM   #2
and here some pictures what I'm writing about
Old 7th December 2011, 07:23 PM   #3
Yes I was intrigued when I first saw the Pentaton in Klang & Ton (or Hobby Hifi, I forgot which magazine). Now I seem to remember that you really had to be in the "sweet spot" to have good treble response. Do you experience that as well?
Old 7th December 2011, 07:25 PM   #4
jimbro is offline jimbro  United States
Some pics would be nice. Having a little trouble visualizing. Are they horizontal line array? Which horns from Klipsch? Are the crossovers for the bg20s or the bass or both?
Old 7th December 2011, 07:28 PM   #5
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
I have 8 of cheap Chinese no-name 4" polypropylene cone drivers per side, plus 16 notebook speakers per side as tweeters, in walls. Sounds gorgeous. Nothing curved, nothing special, but sounds fantastic. A pair of 12" woofers in concrete boxes match them well. Sweet spot is all around the listening room, also in the adjacent kitchen.
The devil is not so terrible as his mathematical model!
Wavebourn: We Create Creativity!
Old 7th December 2011, 07:32 PM   #6
>talaerts You're right, it is important to have the ears in the sweet-spot to have the full performance. But half a meter left or right is also okay. For two people it is practicable to listen. But sitting in the right position it is absolute phantastic and holographic-a guitar sounds like that and a big orchestra does too. The rate is correct, equal if a single guitar or a big orchestra. The best I've listened to for years
Old 7th December 2011, 07:32 PM   #7
As background info, Koserthal was inspired by this "Pentaton B" system:
Old 7th December 2011, 07:33 PM   #8
The pics came in while I was typing. Looks good. It was the "beginning middle to the outside" that threw me. Glad your ceiling's not lower.
Old 7th December 2011, 07:50 PM   #9
Yes, this is the Pentaton BB that inspired me to build a line array from the floor up to the ceiling. To get the ten-in-line i had to derate the high and enlarge width. The capacity of the cabinets are the same as the original ones
Old 7th December 2011, 09:05 PM   #10
Radugazon's Avatar
I like the idea, and the horns behind are very well integrated in the visual design.
But can somebody explain me the relevance of a curved baffle claiming " to put each speaker at the same distance of the ears" when the filter is a 3 ways ( and not a first order) introducing it's own phase shifts ? Is this enough offset to compensate everything at once ?
curved front open baffle pforeman Full Range 0 20th February 2009 12:38 PM
to build curved front panel Jordan JX92? goodspeaker Full Range 44 14th February 2008 11:19 AM
Curved line array wilbur-x Multi-Way 0 11th February 2008 12:48 PM
Visaton FRS8 line array & W170S Miha Multi-Way 16 3rd November 2004 11:24 PM
Page generated in 0.10275 seconds (79.62% PHP - 20.38% MySQL) with 11 queries
