Old 4th December 2011, 02:48 PM   #1
Default Need help with 2 way fullrange project.
Hello. I am working on my lastest project for a friend of mine. I have gotten a pair of 3 inch fullrange speakers. They go from 92hz to 32khz. I was wondering were I can put a cap to these drivers and use them as a mid/tweeter/super tweeter. Now I thought on adding a fullrange woofer to this project. I am looking at a 5 inch fullrange from fostex. It is the
ff125wk speakers. I will build the port box fostex has plans for this driver. Now for the smaller driver I plan on doing in open baffle on the top part. I would like to be able to play these 3 inch fullrange driver fairly loud. oo the drivers I am breaking in right now is the ff85wks. So please let me know what you think? I need all the help I can get.
P.s. is there a diffrence between a non-polarized capacitors and film and foil and metallized polypropylene caps? I have used t he dayton audio caps and they are really nice. I have also used the audio caps as well and the auricaps too. I know that is it 132uf for 125hz cap and it would be alot of money and I would like to use the most cheapest most natural way of making thses speakers sound real. Thanks again. jd
Old 5th December 2011, 01:49 PM   #2
jimbro is online now jimbro  United States
Take a look at this - http://homepage.mac.com/tlinespeaker...TLs-280411.pdf. It uses el166s as the woofs and I think your ff85wks would plug right in. Reviewed very well by those who have built them (I'm not one).
Old 5th December 2011, 01:50 PM   #3
Page 3 on that link by the way.
Old 5th December 2011, 02:35 PM   #4
GM is offline GM  United States
GM's Avatar
Greets!
Indeed there is! The "Sound" of Capacitors
Well, its linear excursion at rated power limits it to a ~500 Hz XO at best, so if they were mine, I’d put them on a ~ 4.8” wide OB capped off at 1.0 kHz [or higher if I could see the driver move hardly at all at rated power].
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 5th December 2011, 04:49 PM   #5
chrisb is offline chrisb  Canada
If budget and physical space permit, and you still want to stick with Fostex for the woofer, I'd suggest either the 165 or 205 WK. As a mid/tweet in either separate enclosures or isolated within something like the MTM/MLTL that jimbro referenced, the FF85WK is silly good. Passive Series XO about 320-350Hz IIRC. If you've got or care to build multiple amp channels, PLLXO has lots of advantages.
you don't really believe everything you think, do you?
community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi
Old 6th December 2011, 08:04 AM   #6
dewardh is offline dewardh  United States
Why use a "full range" for the woofer at all? Just use a woofer . . . and cross it into the full range drivers you've got at maybe 300Hz. (which leaves plenty of overlap to use a simple low order crossover).
Need advice for next project - should I go fullrange or multi-way? Bubba Zanetti Multi-Way 14 16th February 2009 07:19 PM
My first fullrange project - FR125s Foxx510 Full Range 23 8th August 2007 11:03 PM
Cheap fullrange project arcturus Full Range 34 27th April 2005 06:26 PM
fostex FX120 or FE108EZ ? ( was : need help fullrange project) punk Multi-Way 0 11th March 2003 12:43 AM
need help : fullrange speakers project punk Multi-Way 24 28th February 2003 08:47 PM
Page generated in 0.12352 seconds (75.67% PHP - 24.33% MySQL) with 10 queries
