If I have a pair of EL70s per box (wired in series) with both drivers firing forward and I want to roll off the lower driver with Fc around 700 Hz, is it as simple as putting a ~57 uF cap across the leads of the lower driver?
#2 | |
Previously: Kuei Yang Wang
I used this trick in the 80's with Schulze KSP215 (East German Full Range drivers made for Studio monitoring) to allow more power handling and loudness, withpot loosing this "single-driver" sound. Ciao T |
#3 |
Is the Zobel necessary, or just desirable?
So you're saying the upper driver should have a Zobel network (resistor and capacitor in series) across its leads, and the lower driver should have a Zobel network across its leads in parallel with a filtering capacitor? |
#4 | |
With the drivers I used then (~ 25 Years ago) they where essential. If your drivers have very low voice coil inductance (by virtue of having a copper cap over the pole piece) you may be able to do without. Quote:
Ciao T |
#5 |
Great, thanks very much.
The drivers are MarkAudio/CSS/Planet 10 EL70s, with a reported Le of 0.256 mH. For anyone finding this thread, here's the most to-the-point article on Zobel circuits I found: TA Speaker Topics - Neutralizing L(e) with a Zobel |
#6 |
The EL70 impedance sweep looks a little funny as the fs appears incorrect. Still, even if it is shifted a bit the impedance rise does not look so severe. Please post your findings with and without the Zobel. Thanks.
#7 | |
In addition, there is an important piece to note. Shunting one driver at MF/HF does not provide anything like baffle step correction, due the drivers being in series all that happens is that we slowly "belnd over" to single driver operation at higher frequencies. So any baffle step correction still needs a series LR circuit in series with the Speakers! What the Cap across the second driver does is to create a system that has greater LF power handling/displacement/SPL than a single driver, but at high frequencies acts as pure single driver system, with non of the comb filtering etc associated with multi-driver systems. Ciao T |
#8 | |
frugal-phile(tm)
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#9 |
I think he's refering to what we discussed here: EL70s have arrived!! starting at the bottom of the page. You corrected the data sheet, but Bob never did upload the correct sheet to the site.
This is the proper sheet: http://homepage.mac.com/planet10/CSS...ata-080909.pdf |
#10 | |
| 4 ohm drivers in series w/ crossover | Einric | Multi-Way | 3 | 4th June 2011 07:31 PM |
| Wilson WITT Series I Drivers | dritter_1999 | Full Range | 0 | 5th April 2006 06:20 PM |
| X/overs with 2 drivers in series Q?'s | rolfy72 | Multi-Way | 4 | 8th October 2003 04:38 PM |
| Drivers in series - ok or bad? | Circlotron | Multi-Way | 14 | 28th October 2002 04:15 AM |
| PSB Image Series Drivers | wwolf | Multi-Way | 0 | 28th December 2001 08:27 PM |
| Page generated in 0.11973 seconds (77.98% PHP - 22.02% MySQL) with 10 queries |
