I know it is taboo to talk crossovers here, but it has been suggested enough times around here that some people like to add a tweeter to their FR systems for some more "air" up top.
I am just playing with this idea for now, but I'd like to know your opinions on this...
I am glad I don't know what jitter is, otherwise I might hear it. |
#2 |
Hi Cogitech,
1. Can you post at least the tweeter's specs? It would be interesting to see the attenuation at the tweeter's Fs. 2. Just curious, what do you like about this tweeter? Have you heard a good ribbon tweeter? 3. 1st order parallel is a classy choice. Are you familiar with 1st order series? It has some unique advantages / tradeoffs. |
#3 |
Not to sound like Debbie Downer, but probably not. I take it those xo values from an online calculator or something? That tweeter will likeling ring at Fs (right around 2000hz I suspect). 2nd order would protect it better. Also, if there is a phase mismatch, which is quite likely with a dual woofer arrangement, you could end up with a null at the xo point. The acoustic center offset between the woofer and tweeter are very close to the half wavelength at 6000hz.
I've worked with the larger version of that tweeter (nd28f-6). It sounds great |
#4 | |||
B) I love the form factor. For my application (retro-fit) this is one of the only tweeters that will work. Drill a hole and shove it in C) The price is right. Quote:
#5 | |
If I crossover at 6k, how will it ring at Fs (2283hz) ? Forgive my ignorance, but I don't understand the third-last sentence (last sentence of first paragraph, to be precise). Is that a bad thing, or a good thing?
I am glad I don't know what jitter is, otherwise I might hear it. Last edited by cogitech; 3rd December 2011 at 05:06 AM. |
#6 |
I see now that I misread the specs on the tweeter. They are 6ohm. Not sure how I made that error... perhaps there is an 8ohm version as well...
#7 | |
An oversimplification but whereas parallel 1st order consists of two "separate modules," (a high pass and low pass, the values of which you might choose more or less independently), series crossover has an interesting property in that the cap and coil work together to split the signal "sort of perfectly." I've not stated it well but that's the basic idea. I think it's even simpler than the crossover you've suggested (same number of parts but potentially more tolerance and potentially easier to dial in). The trick is that the drivers will have significant overlap as 1st order, and while that has good phase characteristics (which are -totally- audible in my limited experience), the shallow attenuation means you want to cross well away from the tweeter's Fs. And well away from any midrange / treble problems that the fullrangers might have on their top end (probably not a consideration with widebanders but a consideration for woofers of larger size). I'm definitely no expert but your project is similar to something I'm fiddling with. |
#8 | |
Perhaps an L-pad would be handy for the tweet, so I can choose just how much "air" I want. The other option is to just stick with the EQ or "Treble" knob and leave well enough alone. I'm just a bit of a tinkerer and need something to tinker with, or at least think about tinkering with.
I am glad I don't know what jitter is, otherwise I might hear it. Last edited by cogitech; 3rd December 2011 at 05:26 AM. |
#9 | |
Take a look at Madisound's HDS kit, they have been there since 1972 and the fellows there designed this. I've built 10 so far, and using one for my center channel. It will take a couple of months of break in period, but once it get going, it's remarkable. The other 9 are spread out among friends, they think they are great and are spreading the word around. HDS Home Theater Kit - Parts Only: Madisound Speaker Store |
#10 | |
But with a first-order crossover, the attenuation is only 6db/octave so 6k is actually very _close_ to Fs. Let's say it's an octave and a half (1.5k is two octaves away from 6k). So it will be attenuated 6db at 3k, 12db at 1.5k. So let's call it roughly 9db at Fs. That's probably not enough attenuation and so for a first order crossover, for that particular tweeter, you probably want a higher crossover point (or alternatively, a steeper slope but there goes all the fun!) Air in my experience is around 12k. Don't get discouraged, you are on a good and exciting (and affordable) DIY path with first order crossovers. The quality of sound is in keeping with single driver principles, especially the series variety. |
| Will this amplifier work with this subwoofer?? How would the wiring work? | hd2008 | Car Audio | 0 | 20th March 2011 08:57 PM |
| Will This Work? | sousmielie | Class D | 6 | 27th December 2005 05:53 PM |
| It Should Not Work ! | f4bok | Solid State | 3 | 6th September 2004 05:33 PM |
| Would this work | cuallito | Tubes / Valves | 5 | 12th April 2004 12:58 AM |
| Would this work? | Saurav | Tubes / Valves | 36 | 23rd November 2003 06:49 AM |
| Page generated in 0.15548 seconds (81.53% PHP - 18.47% MySQL) with 11 queries |
