Old 26th November 2011, 12:02 PM   #1
Default Driver and enclosure recommendations for small room.
Hello diyAudio community.
I am putting together a game plan to build a Class A amplifier and fullrange speaker stereo system for my bedroom. My bedroom is 13ft x 13ft. The speakers will be close to walls and probably placed in or near corners. My budget for drivers is $100 for the pair. The only cabinet requirement is simplicity, meaning the cabinet must be fairly easy to construct. The cabinet plans must also be free of charge. I will probably build a small subwoofer in the future. I would like to see some driver and enclosure recommendations that will fit my application. Thank you so much for the time taken to read and reply to my post.
Old 26th November 2011, 08:21 PM   #2
jimbro is online now jimbro  United States
Though I've never heard them, I think Pensils for chr70 or el 70 would fit your bill. The drivers are $38 ea I think and the boxes are easy to build and plans are free on Planet10's website. From what I've read either would do very well in a room like yours. I'd probably choose el70s because of paper cones and better bass.
Old 26th November 2011, 08:54 PM   #3
zman01 is offline zman01  Bangladesh
IIRC the EL70 does not go into Pensils, however the CHR70 does.
Good suggestion from Jimbro on the Pensil. Another easy build is the P10 Half Tower; works with both CHR70 and EL70.
Old 26th November 2011, 09:40 PM   #4
Send a message via Skype™ to Rullknufs
The EL70 sure is a very good driver! Haven't compared it to the CHR70.
Old 27th November 2011, 03:36 AM   #5
To quote my illustrious governor - "oops"
Old 27th November 2011, 07:09 AM   #6
chrisb is offline chrisb  Canada
EL70 works like a charm in the dual driver MT, and I'm sure wouldn't be hurtful in the single drive version thereof - the build would be as simple as a Pensil, and uh, I forgot the third thing
you don't really believe everything you think, do you?
community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi
Old 27th November 2011, 07:23 AM   #7
frugal-phile(tm)
planet10's Avatar
Might be a bit more challenging than you need, but corners make me think Frugel-Horn Mk3 with FE126En
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 27th November 2011, 11:54 PM   #8
Thanks guys! Those where the two designs I was considering.
While the Frugal-Horn calls my name, I think I will build the Mark Audio R70 just because it will be cost effective and simple to build. I will be building First Watt F5. Will the R70 work well with this amplifier? I want to build the FE126En Frugal-Horn but I lack the tools to make accurate angled cuts.
Thanks again guys!
Old 28th November 2011, 01:09 AM   #9
frugal-phile(tm)
planet10's Avatar
F5 will be good
dave
Old 28th November 2011, 01:16 AM   #10
Bigun is offline Bigun  Canada
Bigun's Avatar
I have a pair of EL70's and they are really nice, but I am always conscious of the lower impedance - 4R nominal - which allows more power for the same amplifier power rail voltage compared with 8R nominal, but requires higher Class A bias current and hence more heat.
CHR-70 is nominal 8R and looks to have a more extended freq. response (see attached, EL70 on left - courtesy of Mark Audio)
If you like the FH3, you can, if I remember, get a ready-cut kit of wood from Planet10.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
15 ohm driver & TQWP for small room? waam68 Full Range 9 26th August 2011 09:25 PM
Driver and enclosure for 4 watt amp, 12x12 room, moderate volume chamber music? zenga123 Full Range 55 16th December 2010 02:06 PM
have enclosure, need driver recommendations talis Subwoofers 6 2nd January 2007 03:08 AM
Ported Enclosure Design w/o Driver Theil-Small Parameters misterbobman Multi-Way 6 29th March 2005 02:06 PM
Would ported or sealed enclosure be best for this driver in small PA system? The Paulinator Multi-Way 26 25th April 2004 03:38 AM
Page generated in 0.10766 seconds (77.62% PHP - 22.38% MySQL) with 11 queries
