#11 | |
frugal-phile(tm)
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#12 | ||
you's pays your money, and you's make your choice
you don't really believe everything you think, do you? community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi |
#13 |
I usually lean towards paper cone drivers but I like that the CHR70 has a little more top end. However, bass response is a little more important to me. What about the CHP70? I love the look of the natural paper cone, but how does it compare to the other drivers mentioned for my application?
Maybe I will get a table saw for Christmas, then I will be able to build the Frugals this spring. Thanks for all the replies. |
#14 | |
Partly the answer depends on which CHP70? I'm not sure how many folks have had the opportunity to compare the earlier (European) and current G2 version and either version of CHR70. In this size range, I've heard CHR70 (both gens) CHP70 G2, EL70, Alpair7 & 7.3, and Alpair6 M & P in a range of enclosures - I certainly couldn't nominate an overall winner for all applications. Is your inclination to the CHR based on actual listening, or forum chat? - that's always a toughie. The FH3 enclosure has certainly been found to be compliant enough to work well with a wide range of 3-4" drivers (all of the above named and more) - with some models adjustment to damping / fill is required to tame bass output. how's that for clarifying things?
#15 |
you'd make a good politician
![]() Personally, I don't like the colour scheme for the CHP, a combination of black and tan. OK if you're mixing a drink but otherwise it looks weird - maybe it's just the datasheet that shows it in a bad light ? The freq. response may not be to your taste either.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig. |
#16 | |
frugal-phile(tm)
dave
#17 | |
#18 |
frugal-phile(tm)
Maybe... getting this to XO smoothly with the peak, followed by the shelf may be an issue unless in the digital domain, and if that, it could just be EQed flat.
If you are going to add a tweeter, might as well start with CHBW, which has a 10dB lower shelf & not quite as dramatic a peak, making XO easier (and a very good XO already developed -- kits can be had from Bob/CSS, not sure what the status of the circuit is) ![]() The FR anomalies are likely accompanied by phase anomolies. That said, Chris is sheduled to put some holes for some ERT26 on the empty faces of the microTowers, we may be able to turn the shelf into an asset as we turn them into MTII. dave
#19 |
Expect some trouble at 43 and 87 Hz.
High current requirement is the bane of high fidelity |
#20 | |||
I will be ordering from Madisound, so I am referring to the Gen2.
I understand it is not optimal to fix acoustic/mechanical problems with electrical solutions but I have no qualm using digital signal processing to take care of any problems a dinky little 4" driver may impose. As always, Thanks for the replies. |
| 15 ohm driver & TQWP for small room? | waam68 | Full Range | 9 | 26th August 2011 09:25 PM |
| Driver and enclosure for 4 watt amp, 12x12 room, moderate volume chamber music? | zenga123 | Full Range | 55 | 16th December 2010 02:06 PM |
| have enclosure, need driver recommendations | talis | Subwoofers | 6 | 2nd January 2007 03:08 AM |
| Ported Enclosure Design w/o Driver Theil-Small Parameters | misterbobman | Multi-Way | 6 | 29th March 2005 02:06 PM |
| Would ported or sealed enclosure be best for this driver in small PA system? | The Paulinator | Multi-Way | 26 | 25th April 2004 03:38 AM |
