Hello diyaudio community,
I had an idea for a small desktop speaker which should work using the TQWT principle:
What do you think, will it sound ok?
Technical stuff:
The pipe is nearly 70cm long so it should amplify 122 Hz. I want to get a little bit of bass out of it but I have no idea how I can make the pipe longer without over complicating things.
The slot is 3x100x30mm, is this alright?
I plan using the TangBand W3-871SC.
Is it possible to simulate the enclosure before building it (I'm on a mac)?
Thanks in advance
~Flo
Technical stuff:
Thanks in advance
~Flo
I just did my first simulation using AkAbak, here is what I did:
Can someone check if I did everything right? Here are the TSP of the TangBand: http://www.tb-speaker.com/detail/1208_03/w3-871sc.htm
Shall I add more parameters?
Thanks in advance
~Flo
Thanks in advance
~Flo
