Old 22nd November 2011, 04:56 PM   #1
toobhed is offline toobhed  United States
Default line array impedance issue
I'd like to build a small speaker with 3 indentical 3" drivers, each 8 ohms. I'm having a hard time figuring out how the amp will see between 4 - 8 ohms.
I could parallel two of them for 4 ohm, but this will mismatch with respect to the third 8 ohm. Could I use a resistor leading to the two paralleled drivers to bring the pair up to 8 ohm and then parallel this 8 with the other single 8?
If not, is there any other way to get 3x 8ohms to be seen by the amp anywhere between 4 - 8ohms. Thank you!
Old 22nd November 2011, 06:03 PM   #2
chrisb is offline chrisb  Canada
actually why not use this as an opportunity to power taper -as per page 6 of
http://www.madisound.com/pdf/TheCHRA...lan-250811.pdf
while these plans are specifically for the MA CHR70.3, the wiring logic would work equally for triples of any driver - and let's assume that there could be advantages to power tapering a triplet of small/full range drivers in a compact line array
you don't really believe everything you think, do you?
community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi
Old 22nd November 2011, 06:07 PM   #3
Thanks for the tip Chris, I'll study the plan and hopefully implement. But just out of curiosity, would the resisitor approach function?
Old 22nd November 2011, 06:09 PM   #4
Chris please disregard my previous post...I looked at p6 and it is the perfect solution! Thanks again for your prompt help!
Mario
Old 22nd November 2011, 06:53 PM   #5
Mario
actually thanx should go to Dave & the other real brains behind the design
Wanting to build a line array. Newbie troubles with impedance and efficiencies. GuyPanico Multi-Way 13 14th September 2011 09:56 AM
Full Range Line array Efficiency and Impedance Question? rjp366 Full Range 10 23rd August 2009 06:42 PM
Line Array Impedance HELP Dominick22 Full Range 7 21st June 2007 11:48 AM
Help with NSB Line Array issue cytokine Multi-Way 60 10th June 2006 03:14 AM
Page generated in 0.06995 seconds (83.00% PHP - 17.00% MySQL) with 10 queries
