diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Full Range (http://www.diyaudio.com/forums/full-range/)
-   -   Windermere^2 with WR125st plus ERT26 (http://www.diyaudio.com/forums/full-range/200803-windermere-2-wr125st-plus-ert26.html)
jonastus 19th November 2011 02:15 PM
does this design would work or I better stick with the el70 speaker in it
zman01 19th November 2011 03:34 PM
Do a search on the forum - IIRC there was one member who built a pair with EL-70 and was very happy with the results. EL70 works in a lot of other designs too - so if you want to build something else later, you can use them.
Cal Weldon 19th November 2011 04:19 PM
2 Attachment(s)
Well, I have both and appreciate them both but for different reasons. The 125's with tweeter are a little more to my liking as the highs are more prominent but those little EL 70's, while a "softer" sound, never cease to amaze. Can't say I prefer one over the other, sorry. Never mind the woofer in the center, it's no longer a part of the mix. :)
jonastus 20th November 2011 10:28 PM
so I be better to build the rosa enclosure for the two wr125st since its for h.t. use ?
planet10 20th November 2011 11:11 PM
The enclosure for 2xWR125 is Calhoun.
dave
jonastus 21st November 2011 11:38 PM
and where could I found it ?
Cal Weldon 22nd November 2011 12:14 AM
1 Attachment(s)
I think Dave might know where and the nice thing is, it's a simple build. Here's the inside:
planet10 22nd November 2011 02:04 AM
Originally Posted by jonastus (http://www.diyaudio.com/forums/showthread.php?p=2790475#post2790475)
Bottom of the table, in the middle
The Spawn Family of Double Horns
dave
jonastus 22nd November 2011 03:01 AM
thanks a lot
jonastus 27th November 2011 01:49 AM
whats the advantage to put the second speaker on the side wall because I find the box more beautiful with the 2 speaker in front
and I will save the tweeter for an other project to
Copyright 1999-2017 diyAudio
