Hey all, first post.
I've been recently fascinated with back loaded horns. The look em is just awesome. I'd really love to get into making some of my own. But I feel like I'm getting swamped with information. I've found a few articles on them, and I've tried to digest what's been said in some of the threads here, but in the end I always end up scratching my head. So, where would be a good place to start? Do I need to know a ton about other speaker cabinet styles before I can really get into back loaded horns? I'm very new to speaker building, having some fun building cabinets for Leslie speakers, and I'd really love to be able to design my own speaker cabinets. Thanks! |
#2 |
Hello,
look my HP. here a simple guide line for construction: Calculation of expo horns If you have AH, AM, l, k still lacks the flare rate: ln (AM / AH) / l = k so you can see the surface each point out (Al): INV ln (l * k) * AH = Al l m, AH + AM + AL in square meters By Al e.g. m in width and divide you have the distance in meters AH = Horn throat AM = Horn mouth k = flare rate l = length Lengths and flare rate VALUES K VALUES: 0.37 ~ 10 Hz 0.55 ~ 15 Hz 0.7 ~ 19 Hz 0.9 ~ 25 Hz 1.1 ~ 30 Hz 1.3 ~ 35 Hz 1.48 ~ 40 Hz About an octave above k plays the horn, if the length matches. At BL horn lengths over 3.4 m, you get a suck out below 100 Hz 4/lamda lengths VALUES 3.4 m ~ 25 Hz 2.8 m ~ 30 Hz 2.4 m ~ 35 Hz 2.1 m ~ 40 Hz 1.7 m ~ 50 Hz 1.4 m ~ 60 Hz Most of my horns open the last~ 75 cm (look ALPHORN) with a double or triple k, to get a better mouth+room crossover.
http://www.hm-moreart.de |
#3 | ||
Thanks for replying!
Thanks again! |
#4 |
#5 | |
Looks interesting, but will it run on a Mac? I've really got to get Windows/BootCamp installed and running on my computer, but at the moment I don't have access to any Windows computers. |
#6 |
Really? Not HornResp?
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#7 |
Hello,
AH= horn beginning AM= horn end AL= the length which you need for construction, folding etc. Hiifi horns are allways to small and short so you get dips and peaks. look the impedanz of horns, if someone published it like me. If you donīt know what an oktave is, read before building
#8 |
http://www.hm-moreart.de Last edited by hm; 20th November 2011 at 08:28 AM. |
#9 |
Hi GM,
AJ Horn is definitely simpler for me for BLH. Once the driver params are in the "library," you just specify rear-loaded, coupling chamber, mouth, length and throat. No summing of curves, and some of the geometry features are assumed (e.g., that you're building a "flat" constant-width cabinet). So for me, the handy feature I need is that it generates a simple build-plan for the horn, in the form of a list of numbers (you enter the cabinet depth and it gives you the "width" along the curve plus cross-sectional area). It does seem to model fewer factors (for example, baffle step does not appear to be modelled, and it appears to assume the driver and mouth are a point-source, i.e., not taking into account the offset between them into the summation -- but I am using version 5, and there is a version 6 with more features, and anyway, I could still be wrong about version 5). I started using it in part because the Replikon guys were (and it seems, most German horn hobbyists). I haven't given HornResp a fair shake but will be doing so in the coming year. |
#10 |
Greets!
Good to know, thanks! GM
| Back Loaded Horns | Helmuth | Multi-Way | 145 | 18th April 2012 10:03 PM |
| How to model Back Loaded horns in Hornresp? | Boscoe | Full Range | 2 | 17th January 2011 08:00 AM |
| Sub amp phase w/ back loaded horns (again) | wicked1 | Subwoofers | 6 | 4th August 2010 04:52 PM |
| The Best Program for Back Loaded Horns | Patrick Bateman | Full Range | 2 | 21st December 2009 04:04 PM |
| Op amps and back loaded horns | MikeFarad | Full Range | 1 | 1st January 2007 04:50 AM |
| Page generated in 0.12685 seconds (82.43% PHP - 17.57% MySQL) with 11 queries |
