How to Treat Passively Peaky FullRange Drivers
Old 18th November 2011, 06:48 PM   #1
FullRangeMan is offline FullRangeMan  Brazil
FullRangeMan's Avatar
Default How to Treat Passively Peaky FullRange Drivers
This thread is about keep FullRange drivers crossoverless to listen its Harmonic Integrity, that is the best feature a FR can delivery to the music lover.
If you are a CrossOver lover you may be frustated here.
Some Full Ranges drivers had strong mid-treble response, to keep it crossoverless, is need some passive treatment to smother the high frequencies.
Of course passive, is a non electronic part, as inductor, capacitor, DSP etc.
1) First: around all the box corners, even the small ones, with a triangular or L shape profile of wood or MDF. Alternatively can be used that soft massa/dough of caulk, avoid plastic or metal parts.
2) Second: Paint matte black all walls inside the box, even the Baffle, it is not difficult with a spray can.
3) Stuffing all the fullrange magnet with 30 to 50mm black foam or dark blue or brown. Pressed wool 20-30mm also is good. You will need some glue. Please note, that foam begins to crumble/mill after some 10 years, so use a new quality sample of medium density. Avoid 10mm carpet or non shaggy rug.
4) Stuffing inside the box as recommended by the driver manufacturer or even more. If the box is BassReflex, stuffing the duct also, with dark foam, not the inside of the duct/flute of course, but the outside of the duct.
5) Foam will raise the bass response too, that is great, as I am a bass fan.
Please Note: Foam and wool blanket use space in the internal volume of the box, the white Polyester blanket will not occupy space in the box litrage.
If you had a suggestion or a new trick, please fill free to post here to us.
Cheers
>Never go to a psychiatrist, adopt a cat or dog from the streets. On the streets pets live only two years average.
Old 18th November 2011, 07:31 PM   #2
Another trick, Use different thicknesses of wood for the enclousere:
BAFFLE = 30mm
BACK = 10 to 15mm
SIDES = 20mm
Old 18th November 2011, 11:24 PM   #3
ultrakaz is offline ultrakaz  United States
How does painting the enclosure (inside and baffle) matte black "smother the high frequencies"?
Old 19th November 2011, 12:18 AM   #4
The black colour decreases the resonances. Different thicknesses of wood too.
Old 19th November 2011, 12:48 AM   #5
diyAudio Member RIP
The paint will have next to no effect unless its very thick. Bitumastic car
underbody spray (anti-chip) will be far more effective than matt black paint.
Triangular fillets in all corners will have next to no effect regarding the issue.
Stuffing of the box if overdone done will kill any bass.
None of the above will "smother" the high end output of a FR driver.
Passive means no active electrical components, not no electrical components.
Passive electrical filters on FRs by making the response flatter also improve
the phase response and transient response. No reason not to use them.
A correction filter is not a crossover and has none of the issues of a crossover.
rgds, sreten.
Old 19th November 2011, 02:00 AM   #6
bushhorns is offline bushhorns  United States
bushhorns's Avatar
Of course since the Fullrange "peakyness" is not to be denied the best solution is to design the right cab that " boost's" the lower freq. Now it is easier said then done. That were all the inovation pays off the most!
Old 19th November 2011, 02:49 AM   #7
The black paint effect varies according to the speaker. Sonus-Faber use just black dye, not paint, but charge a lot for his speakers.
A 90 square corner are a hard load(mainly in narrow enclousures) to light weight paper cones, some times under only 10 grams for a 8 inches driver.
This effect is so important, pro-audio speakers use trapezoidal enclousures, to avoid square corners.
Varies according the speaker type, model etc.
Again, varies according the FR used. I had success in lower the hi freq of a pro audio FR, each speaker is a diffrerent case.
Electrical components had no irrelevant effect on the music signal, for this reason they are used to modeled the music signal.
Artificial flat response, created by notch filters made no improvement in the music signal. Instead it made a corruption in the original music signal.
If the sound result is good or bad, is a personal taste. But not suited to a purist fullrange.
Even a small capacitor in the music path, will change(corrupt) the music signal.
A fullrange driver is what it is, good, very good or bad, what it had best is the Harmonic Integrity, this H.I. is the original recording sense, it not exist with filters as know by FR fans.
rgds, sreten.
Old 19th November 2011, 04:12 AM   #8
type is offline type  United States
I don't know about paint, but I wonder how this would work as a sound deadening material:
https://www.getflexseal.com/?tag=im|...a_bid=a4cc8494
No one laugh
Old 19th November 2011, 02:33 PM   #9
diyAudio Member RIP
.... this H.I. is the original recording sense ......
That is completely wrong. It is impossible to sensibly discuss dogma.
Harmonic Integrity ? I doubt you can sensibly define what this is,
other than by saying so and so messes it up, messes what up ?
Again a dogmatic approach impossible to sensibly discuss.
rgds, sreten.
Old 19th November 2011, 03:12 PM   #10
Parasonic is offline Parasonic  United States
Parasonic's Avatar
No one laugh
Not laughing, but does the stuff stank?
Terry
Melody, harmony, timbre, rhythm
How to Treat Passively Peaky FullRange DriversHide this!Advertise here!
New fullrange drivers - does anyone know these? Spatz Full Range 25 17th June 2013 01:38 AM
Fullrange Drivers From China! thetubeguy1954 Full Range 44 25th December 2009 09:44 AM
Which sub to use with fullrange drivers ? Bubba Zanetti Subwoofers 11 2nd February 2008 08:36 PM
Passively baffled jmiyake Multi-Way 0 3rd February 2003 11:26 PM
Copyright ©1999-2017 diyAudio
