Dallas II plans needed Dallas II plans needed - diyAudio
Old 17th November 2011, 10:30 PM   #1
Trileru is offline Trileru  Romania
Default Dallas II plans needed
Hello everybody. I want to build this enclosure for my Fostex FE206E but I could only find a set of plans without the cutting dimensions. The only measurements were on a built speaker witch has a lot of strange angles, so I couldn't figure out the exact cutting dimensions before cutting angles from separate pieces. A layout with the cutting is presented but no dimensions. As it will be hard anyway to source the birch, I want to cut to exact precision. As well, does anyone know if solid birch is good or do I need ply birch for this project? Thank you
Old 17th November 2011, 10:56 PM   #2
chrisb is online now chrisb
probably the most accurate dimensioned drawings for the DallasII you'll find
http://homepage.mac.com/tlinespeaker...asII-plans.pdf
Old 17th November 2011, 11:12 PM   #3
Well I have those, I will just cut on the safe side and go from there. Thank you anyway as I know what I have to do now
Old 18th November 2011, 01:38 AM   #4
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
Windows ate the original plans, all that exists has been gathered together into the pdf Chris pointed to. Dallas II have been built from that.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 20th November 2011, 02:04 PM   #5
Thank you. I will get what is needed then come back here with updates and pictures.
Old 23rd November 2011, 11:31 PM   #6
Speed is offline Speed  Canada
Draw it out full size and use a sliding bevel to transfer the angles to your saw. I will always do this instead of using planned angles. Your execution should always match your full sized drawing exactly with nice , tight joints.
Old 25th November 2011, 02:47 AM   #7
squalor is offline squalor  United States
squalor's Avatar
I offered in your other thread. Also, see this thread.
BTW, thank you planet10 for all you do for the community.
Old 25th November 2011, 09:55 AM   #8
Very nice! I can't wait to start the project! Seems that I'm ok with my current tube amp setup, will start to build it than after the casing is done I shall start this project. Need to get some tools first so I make it easier. With all this info about this it shouldn't be hard to get it done as close as possible to the original concept. Thank you for your support, I appreciate people getting involved!
Dallas II plans neededHide this!Advertise here!
Fostex Dallas II maartentje Full Range 14 28th February 2017 07:23 AM
Dallas III plans? wixy Full Range 5 6th April 2013 04:54 PM
Dallas II plans Novacaine1968 Full Range 6 13th February 2010 12:42 PM
Where is the Dallas II amisdad Full Range 16 5th November 2005 04:57 PM
Copyright ©1999-2017 diyAudio
