FAST subs under MA drivers FAST subs under MA drivers - Page 12 - diyAudio
Old 23rd February 2012, 06:41 PM   #111
gerben00 is offline gerben00  Netherlands
I'm enjoying the 7.3's in a 10 liter bass reflex for a few months now, but all this FAST talk has made me sort of hungry..;-)
Few questions:
-The peerless 10 & 8 inch look great, and the price is good. What would be the differences soundwise between the two?
Somehow my gutfeeling tells me the 10 inch will go lower, but the 8 inch might sound a bit faster.
-I'm not able to use a minidsp (or i would need to build a new amp..), so a first order XO would need to do the trick.
What i get is a 5.09 mH inductor, and a 117 uF cap if i cross at 250hz, does this sound correct? I took the nominal impedances form the specsheets, however since one crosses at a certain point, doesn't that change the effective impedance?
-Are there some budget tricks to experiment with different crossovers? What i mean is for instance testing with electrolytics before plunging out big cash for audiophile grade xo caps? It is going to cost a few bucks this crossover as far as i can tell now..
And thanks all for the info in this topic, learned a lot!
Old 24th February 2012, 03:51 AM   #112
silverhairbp is offline silverhairbp  United States
I have not tried the 8" but the 10" works pretty well. There is a bit of efficiency difference between the two, but not much difference in deep response given the same size cabinet. The 10" is a really nice driver that can be crossed pretty high if needed (makes 1st order easy). The 10" will also provide more headroom than the 8".
A single 10" should work pretty well with an Alpair 7. For a 1st order at 250hz, 5mH on the woofer would be OK and you might just get a single 100uF (Solen makes one) for the Alpair 7. If I were building another system, I might use a 90 litre sealed box with a generous amount of that recycled denim insulation loosely packed.
YMMV.
Old 25th February 2012, 10:19 AM   #113
Thanks Silverhairbp!
In your experience could the 10" work in a fully stuffed enclosure a bit under 40 liters? If i put that in a calculator i get a bump around 100 herz.
I probably might end up using the 8" although i like the idea of surface instead of excursion for bass a lot better.
Old 25th February 2012, 08:49 PM   #114
IMO, the 7.3 is better matched with the Peerless 10" 830668 because of baffle step loss. The 10" will work in 40 litres sealed but will have a steeper rolloff down deep. F3 of around 43hz F10 in the upper 20s. Haven't tried a small box with the Peerless but modeling makes it look like there is less dynamic restriction with a larger box. Not a particularly good idea for deep bass unless the intent is to restrict driver excursion.
And I agree. My personal preference is for shorter excursion with larger speaker area.
FAST subs under MA driversHide this!Advertise here!
Audio Alto with MA drivers? djanci Full Range 15 12th December 2012 09:50 PM
MA AUDIO HK-4000D ,NO OUTPUT TO SUBS WRENCH030380 Car Audio 5 11th March 2011 10:39 PM
Crown MA-12000i / MA-5000i / MA-9000i jack2040 Solid State 4 8th March 2011 01:21 PM
ma audio hk-4000 ,no sound to subs ?MA AUDIO HK-4000,NO OUTPUT TO SUBS WRENCH030380 Class D 2 7th March 2011 11:38 PM
FS: horn subs, drivers, 'regular' subwoofer drivers John Sheerin Swap Meet 0 1st August 2004 11:33 PM
Copyright ©1999-2017 diyAudio
