Frugel-Horn Mk3 Picture Gallery
Old 4th December 2011, 03:19 AM   #31
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
These have been posted before -- the original prototypes -- but with other drivers, here with TangBand W5-1611/
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 4th December 2011, 03:21 AM   #32
frugal-phile(tm)
planet10's Avatar
jonparkhurst posted these on the main FH3 thread, his 2nd pair.
Click the image to open in full size. Click the image to open in full size. Click the image to open in full size.
Old 4th December 2011, 06:05 AM   #33
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
Cal's with the CSS EL70
planet10 needs your help:
Let's help Ruth and Dave
Old 4th December 2011, 02:58 PM   #34
cross reference is offline cross reference  United States
I would love to buld a pair yet simple but, very high (wf). I wonder if the ff125wk or the fx120 would work in the frugel-horn mk3?I have not seen any pictures?
Old 5th December 2011, 06:53 AM   #35
chrisb is offline chrisb
my money's on the FF to work like a charm and give great bang for the buck
like my mind, this space intentionally blank
Old 21st December 2011, 03:32 AM   #36
bhorstkotte is offline bhorstkotte  United States
I thought the design was intended to be corner loaded, yet I see few that are in the posted pics - has the corner loading recommendation changed?
Old 21st December 2011, 04:09 AM   #37
frugal-phile(tm)
planet10's Avatar
Depends on the driver used (and the amount of damping). FE126 likes corners.
For instance, jon's (as in post #32) are now heavily corner loaded with reportedly large improvements in the bottom end (note that there is no longer apair of 15" woofers)
dave
Old 21st December 2011, 12:14 PM   #38
ssportclay is offline ssportclay  United States
Wow, the room itself is a front loaded horn.
Old 21st December 2011, 01:45 PM   #39
jonparkhurst is offline jonparkhurst  United States
Default The room
Dave is correct that there is a huge improvement due to room form and function. In the first set up the 15's were not used, only for the theater that is in that room. I did add a Triad 10 inch in wall sub that I had extra and it filled the lower end perfect down to 20hz, BUT I am MUCH happier with the sound and frequency output in the bedroom withOUT the sub now. Its perfect. Thinking of adding a usb DAC to the passive pre and Decware amp. Anyone want a Triad 10 powered sub..
Jon
Old 15th March 2012, 09:02 PM   #40
nrg2009 is offline nrg2009  United States
Here are my rendition of FH's. I'm building an outrigger with spikes.. Bass is huge, imaging is very detailed.
Frugel-Horn Mk3 Picture GalleryHide this!Advertise here!
Frugel-Horn Mk3 planet10 Full Range 1624 12th June 2018 08:46 PM
Frugel-Horn Mk3 Builds & Build Questions planet10 Full Range 1333 18th May 2018 09:48 PM
Frugel-Horn Mk3 flat-paks planet10 Planet 10 hifi 543 4th February 2018 06:16 PM
Frugel-Horn Mk3 Auditions planet10 Full Range 24 8th June 2012 07:18 PM
Tweeter to complimant CHP-70 in Frugel-HOrn Mk3 Bozeman83 Full Range 9 18th November 2011 09:06 PM
