Old 26th October 2011, 12:00 AM   #1
ljfont is offline ljfont  Canada
ljfont's Avatar
Default FAST: Aperiodic or Folded TQWT
I just got a pair of CSS EL70eN and Alpair6p from my last visit at CSS. (Thank you Bob)
I'm looking to build a FAST two way with a removable supra baffle for both full range speakers. I think the Alpair6p will be better with aperiodic and the EL70eN at folded. I have CSS SDX7 as mid bass and will use it sealed.
What determines aperiodic or folded TQWT? Which T/S parameters should I be looking at?
Thanks.
Old 26th October 2011, 05:38 AM   #2
frugal-phile(tm)
planet10's Avatar
Aperiodic is used when:
1/ you have a driver with too high a Q that you want to put in a box and knock back the system Q as much as possible.
2/ you want to remove (most of) the back wave. Usually in this case an aperiodically damped TL (i use these for midTLs in FASTs)
3/ you want to minimize the size of the impedance of the resonant peak
These are not mutually exclusive.
ML-TQWT (i prefer ML-Voigt), toincreasequanity of bass.
You don'twant to push the A6p at the bottom too much, it is a small driver, and you'll limit its midrange magic.
EL70eN (you must have gotten 1 of the 2 pair i did up for Bob) has substantial bass capability -- there is a good ML-V for it -- and the ML-V will work to maximize that.
In a FAST the bass capability of the ML-V would be lost, so there is not much point. If you are trying to meet up with a true subwoofer below 60 Hz it would be worthwhile (but that is not an SDX7)
There is a minimum modification that i highly recommend for the SDX7, it is pretty simple and very effective. A few of the SDX7 Bob has had i have done this mod to.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Aperiodic boxes with aperiodic TL's - an idea. Shoog Full Range 0 22nd May 2009 05:03 PM
Hybrid aperiodic / ML TQWT Hezz Multi-Way 0 2nd March 2007 05:30 PM
FE167e: Brines MLTL or folded King ML TQWT? roundel325 Full Range 5 15th October 2006 05:19 AM
Folded TQWT for Pioneer A11EC80-02F mxv146 Multi-Way 2 21st November 2004 12:37 PM
how to transform a tqwt into a folded then_dude Multi-Way 25 23rd February 2004 12:49 PM
Page generated in 0.07678 seconds (68.99% PHP - 31.01% MySQL) with 10 queries
