Designing a cabinet for Mark Audio Alpair 7.3
Old 23rd October 2012, 11:59 PM   #31
Studio Au is offline Studio Au  United Kingdom
that would be awfully tricky to try and turn...ill get drawing tomorrow and see what i can come up with.
Old 24th October 2012, 12:05 AM   #32
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
It is not turned. It is assembled from flat panels.
And yes, it is a challenging build,
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 24th October 2012, 12:28 AM   #33
I have wanted to try my hand a coopering, if I make One similar it will be turned on a lathe for a round finish. Those ports are the only real dilemma I can see. Do you know if the Alpair performs well in a sealed box?
Old 24th October 2012, 12:41 AM   #34
frugal-phile(tm)
planet10's Avatar
For mid-tweeter use sealed or an aperiodic TL would be fine.
dave
Old 25th October 2012, 07:20 AM   #35
This is how I think best to make my enclosures.
Layer up concentric teardrop 'rings' of plywood, and turn as a whole on a lathe. After route whole and recess for driver.
Like this concrete pen, but then rounded smooth.
Old 6th November 2012, 01:00 PM   #36
Anyone have any recommendations for a woofer/sub to use in a FAST configuration.
Alpair 7.3 in a turned B&W like sealed enclosure. And the woofer in a big curbed cabinet.
A larger 8"/10"/12" woofer to handle the lower bass.
Any great drivers spring to mind, available to purchase in the UK.
Have my eye on the Peerless XLS 10 (70ea)
Old 6th November 2012, 01:56 PM   #37
Bob Brines is offline Bob Brines  United States
Bob Brines's Avatar
I'm looking at the Peerless 835026. Models extremely well. Being aluminium, it will match the gray Alpair.
Bob
Old 6th November 2012, 02:30 PM   #38
Bill poster is offline Bill poster  Thailand
Bill poster's Avatar
hey nice work! I like where this is going. Ever thought about making an RP of the cabinet shape and taking a mould off it? Carbonology in the UK do a simple kit for this, then u cd produce a beautiful carbon fibre enclosure for the Alpair.
The peerless is available @ Falcon and Europe Audio I think - but what is the power handling on these? The travel doesnt look more than the Hivi M8N's.
Old 6th November 2012, 02:41 PM   #39
Here is the link to the eBay seller
2X Peerless XLS10 Subwoofer P830452 Loudspeaker Speaker | eBay
and the specs
Specifications
Nominal Impedance (Ohms)
Zd
4
Min Impedance
Zmin
5.2
DC Resistance (Ohms)
Re
3.6
Voice Coil Inductance (mH)
Le
0.99
Resonant Frequency (Hz)
Fs
22
Mechanical Q Factor
Qms
3.86
Electrical Q Factor
Qes
0.24
Total Q
Qts
0.23
Moving Mass (g)
Mms
136.6
Suspension Compliance (mm/N)
Cms
390um/M
Effective Cone Diameter (cm)
D
21.1
Effective Piston are (cm2)
Sd
349.7
Equivalent Volume (Ltrs)
Vas
66.90
Force Factor
Bl
16.75
Reference Voltage Sensitivity
dB
86.6
Weight of Magnet (kg)
2.42
Old 7th November 2012, 10:16 AM   #40
Here is a quick mockup.
Designing a cabinet for Mark Audio Alpair 7.3Hide this!Advertise here!
Which Mark audio Alpair ? Ewald Full Range 20 14th May 2011 08:36 AM
WTB Mark Audio Alpair 6 sts9fan Swap Meet 7 30th July 2010 10:49 PM
Mark Audio Alpair 7 application jockel77 Full Range 25 12th April 2010 04:42 PM
Mark Audio Alpair For First Build? d3ll Full Range 10 17th December 2009 07:11 PM
