#21 |
Awesome idea.
![]() Make sure you wear eye protection! |
#22 |
Neat, file those edges.
#23 |
Thought on power them, for a super clean signal could a single Hypex AS2.100 be used?
AS2.100 Have this sealed in a box between the speakers, and run a wire to each driver? Nice to have the DAC and power amp all in one place, is the active crossover needed? |
#24 |
Nice looking design. I will echo the sentiments of those before and say CNC would be an awful waste. What I call "Bendy plywood" would work a treat, otherwise, if you are a glutton for punishment you would cut kerfs in regular sheet plywood to achieve the bending properties / curve required. Its not difficult but is time consuming. The tops are easy enough to shape.
The only other concern would be calculating / measuring the volume of enclosure and even that would not be too much trouble getting an estimate of. I did something around two years ago, a stand mount two way speaker, roughly the shape of an elongated guitar body and used kerfing.
None of us are leaving this world alive. Enjoy it responsibly as you may. |
#25 |
Been researching materials and came across an interesting product.
1mm solid wood backing 7 layer ply (10mm) 4mm solid wood 'veneer' They are engineered solid wood floor boards. I plan on glueing them together onto an 3mm mdf backing to ensure they lie flat an them power sand the finish off. I was looking at them for building a pair of the Pensils, but have decided to do a test mockup using the Alpair 7.3 and one of Planet 10's small bass reflex cabinets. As they were surplus to the flooring shop and a little scuffy I got them for £10 a board. Two should be enough to make a pair. I also plan on putting round lippings on the corners......a sketch up picture to follow. Images below: |
#26 |
#27 |
Having finished the above cabinet, its time to start thinking about the next.
Has anyone seem an Alpair in a cabinet like this. ![]() It would be a challenging project.... Have the 7.3 sat in a turned coopered bowl, on top of 2xlarge subs, Peerles XLS 10" for example. With a curved plywood skin, similar to the B&W 800. Thoughts? |
#28 |
frugal-phile(tm)
Bernie is having me design a 20 sided tapered polygonal cabinet that is essentially a steam-punk version of the B&W mid pod.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#29 |
Any pics dave?
How best to model this? |
#30 | |
frugal-phile(tm)
Only a scan of Bernie's sketch.
![]() Quote:
dave
| Which Mark audio Alpair ? | Ewald | Full Range | 20 | 14th May 2011 08:36 AM |
| WTB Mark Audio Alpair 6 | sts9fan | Swap Meet | 7 | 30th July 2010 10:49 PM |
| Mark Audio Alpair 7 application | jockel77 | Full Range | 25 | 12th April 2010 04:42 PM |
| Mark Audio Alpair For First Build? | d3ll | Full Range | 10 | 17th December 2009 07:11 PM |
