#11 | |
errata: should read as above - operate word being "NOT"
you don't really believe everything you think, do you? community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi |
#12 |
frugal-phile(tm)
To be as stiff as the sheet material used in a convential manner, wall thickness will need to be higher, and all bets are off if you use MDF.
When you cut up the ply like this, you are reducing its strength and the curved shape is not increasing its stiffness. The way to do that is like B&W do in their 800-series. The brace's prime purpose is to draw energy away from the driver so that it is shared with the back of the box and not all dissipated by the baffle. dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#13 |
Cutting so much material with a CNC machine, with all the associated wastage seems an incredibly brutal approach, surely flexi ply or mdf would form the basis of a more elegant solution, it would certainly be cheaper and I suspect stronger. Unless one was getting the material and facilities gratis of course.
#14 | |
frugal-phile(tm)
dave
#15 |
no matter the methodology - CCM - curves cost (time and) money
#16 |
Facilities are free, material is not........did a rough cost, came in at more than i hoped. Using 18mm Birch Ply.
Perhaps a design utilising single ribs, as opposed to a complete hemisphere would allow for a lot less wastage....cost. The miniOnken Sketchup picture has this as it was easier to flip one half than make both sides the same, perhaps this is the way to go? Insert a piece of solid wood matching the baffle to hide the seam? |
#17 |
Nice design but it would be a shame to use this construction method with birch ply - too much waste and you wouldn't be getting the best performance out of the material. It makes more sense with MDF, which is cheaper and could do with some stiffening.
Otherwise go for the laminated, thin ply approach or bendy / kerfed MDF. Best of all, make 'em out of metal. |
#18 | |
#19 |
SAu just to revisit the question, and with a little context. I've worked in a commercial millwork shop for 18yrs - we build a lot of curved reception walls, bulkheads, cabinet doors, etc. A few years back I built something very much along the lines of your design, but with the ribbed skeleton/ multiple layers of rubber ply approach. Not a huge success, and ultimately binned.
For the average DIYer, I'd concur with Colin's earlier suggestion of Kerf-core / Timber-flex etc. You can still use the CNC to route the top, bottom and one or two intermediate braces. Fabrication of the external shell for a Pensil style would be relatively straightforward, but curving of side mounted slot ports shown on the smaller enlcosure would be a bit trickier. It might be easier to build in two sections and join at the back with a full length spine. This would allow you to work on the inside of the curved panels before final assembly. .
#20 |
Update...
The original aim was to try and achieve a teardrop shape, I started designing some speakers to replicate great design products, this one using the same materials as the Eames Lounge chair, with plywood and some solid rosewood. I have recently been sketching out a version based on Ron Arads 'Well tempered Chair' ![]() This was the very quick sketch up model. Utilising a plywood, or possibly hardwood skeleton with bent aluminium or stainless steel wrapped around. Im hoping it will form a organic and rigid shape simply by bending metal, riveted to hold it all taught. Any thoughts?
| Which Mark audio Alpair ? | Ewald | Full Range | 20 | 14th May 2011 08:36 AM |
| WTB Mark Audio Alpair 6 | sts9fan | Swap Meet | 7 | 30th July 2010 10:49 PM |
| Mark Audio Alpair 7 application | jockel77 | Full Range | 25 | 12th April 2010 04:42 PM |
| Mark Audio Alpair For First Build? | d3ll | Full Range | 10 | 17th December 2009 07:11 PM |
