Designing a cabinet for Mark Audio Alpair 7.3
Old 27th February 2013, 10:38 PM   #111
chrisb is offline chrisb
Originally Posted by Studio Au View Post
I heard them last year. At a kef demo and last week again.
They were very impressive. Although not in my opinion worth anywhere near the money.
probably a more important question is whether they're known to be a serious production model (perhaps just custom / bespoke builds), or a technology statement piece with only a (few) traveling demo pair(s)
The goal of both in emulating them was to use create a speaker with apparent single point source. Something the blade does very well. The use of twin drivers to cancel out vibration seems logical too.
something quite well documented by many DIY projects herein
I is too short. When posting I noticed you can see the magnet. (Was made in 5 mins)
My thinking was to turn a come shape that would sit over the magnet like and omni deflector to bounce the sound into the larger cavity. Perhaps tapering the ends ala nautilus.
I've probably mentioned this in other threads, but after a couple of builds a few (5 or so) years back, I'd be concerned about very shallow enclosures in general, and most particularly with very lightweight cones, whether metal or paper.
Your quickie sketch appears to indicate a separate enclosure for the A7 that is tall and very shallow - I'd think a deep, perhaps tapered aperiodic enclosure might work better . Well, indeed I know conceptual drawings for something like that exist.
like my mind, this space intentionally blank
Old 11th March 2013, 11:37 AM   #112
Studio Au is offline Studio Au  United Kingdom
One quick side related question...
Im building 4 pairs of Alpair 10.2's small BR cabinets for a bar.
Im trying to decide on how to power them (cost effectively) Doesn't have to be excessively loud. The easiest solution i can think of it using a 7.1 receiver, running on all channel stereo.
Then I thought that perhaps I can wire them together, run as a sort of line array with one good power amp?
Is this possible, would need 20ft of cable in between each speaker, could do 4 for the left channel and 4 for the right to shorten the overal length. Shall i put this idea away and focus on the multichannel approach?
Old 19th March 2013, 10:40 AM   #113
I made a small and very quickly turned mock up just to see what the rings of plywood, would look when turned. its about 1/3 scale.
Click the image to open in full size.\
Old 19th March 2013, 11:50 AM   #114
hajj is offline hajj  Lebanon
hajj's Avatar
They look like turned hardwood
Old 1st April 2013, 02:24 PM   #115
Still in need of 4x woofers for my project.
Any new suggestions? Ideally under 300
Old 1st April 2013, 09:53 PM   #116
Bill poster is offline Bill poster  Thailand
Bill poster's Avatar
what colour, type of loading etc
personally I like the 8" Dayton's (a little over that budget) 4 of these sealed perhaps
RSS210HF-4 - Dayton High Fidelity Subwoofer 8 inch - Europe Audio
Old 3rd April 2013, 03:29 PM   #117
barackuda is offline barackuda  Slovakia
barackuda's Avatar
Hi, they look very nice, a little rough but as you say its a proof of concept
me like them very much....
I will go with Delta 12 LF in 100L, a little EQ and I get them down to 30Hz with 50W of power, which in turn makes 116dB, too much to be honest... think about it
Danny
Old 15th April 2013, 04:42 PM   #118
barackuda's Avatar
Well? Update?
Waiting eagerly on results and first pics from build
Danny
Old 15th April 2013, 06:36 PM   #119
Still deciding on drivers.
Ive just moved to a new workshop, one guy renting a bench space from me has a CNC, so i'm revising the design to allow for this.
Old 15th April 2013, 06:39 PM   #120
Im keen to try and make these.
Invert the colours, Walnut case, and a ceramic baffle.
The horn shape can be made from the surplus from the teardrops.
Dovetailed solid walnut cabinet Ceramic baffle, Accuton ceramic drivers, good quality compression driver with tractrix profile. Could be very very good.
Designing a cabinet for Mark Audio Alpair 7.3Hide this!Advertise here!
Which Mark audio Alpair ? Ewald Full Range 20 14th May 2011 08:36 AM
WTB Mark Audio Alpair 6 sts9fan Swap Meet 7 30th July 2010 10:49 PM
Mark Audio Alpair 7 application jockel77 Full Range 25 12th April 2010 04:42 PM
Mark Audio Alpair For First Build? d3ll Full Range 10 17th December 2009 07:11 PM
