Old 11th October 2011, 10:52 AM   #1
Default Omni- TL WITH 8" AN, possible practical?
Hi Guys,
First post.
Am looking into building a Omni- TL design to use the 8" Audio Nirvana driver. Thinking of using the Audio Nirvana 8" firing up from an approx 1m triangular with heavily radiused corners (when viewed from above) case with sides approx 12" across. That design should easily give me 2m in line length to play with.
Basically envisage the 8" driver mounted at the top, firing up, in the center of the top of the speaker with a tube from the bottom of the 8" driver and sealed to it with the tube then going to within a few inches of the bottom of the speaker case and then returning to exit around the outside of the 8" driver.
Is having the open end exiting around the circumference of the driver a good/bad idea?
How would adding an extra sub to the bottom of this design change the property's of the TL?
I'll do a few sketches and upload later. Just wanted to get things started. Sure you know how it is when inspiration strikes. Just have to got on with it
Carl
OK Quick photoshop mock-up but hope my ramblings make more sense now.
Speakers will be Active, Bi-amped using a 60w rms per channel into 8ohm T-amp.
Old 11th October 2011, 02:17 PM   #2
GM is offline GM  United States
GM's Avatar
The 'folded' TL is a variation of one of the original bass reflex patent designs, so a good plan IMO. I don't see the 'sub' in the bottom turning out well though since it will tend to audibly modulate the 'mains'.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 11th October 2011, 08:33 PM   #3
Can you explain, How is this different to a bass and mid in an ported or sealed case? is that because of the the fact that they are orientated directly at each other?
Old 11th October 2011, 10:04 PM   #4
chrisb is offline chrisb  Canada
No, even in a vented enclosure the internal pressure by back wave of low frequency driver will be more than substantial enough to modulate other drivers in the enclosure - for example, otherwise PRs wouldn't work.
I doubt you'll find many well executed multi-ways (other than OB) that don't isolate the mid-range/tweeters or use sealed back drivers for the latter
you don't really believe everything you think, do you?
community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi
Old 12th October 2011, 03:18 AM   #5
GM's Avatar
What Chris said plus the woofer would be end loading the pipe opposite the mains, amplifying the modulation, so a 'tail wagging the dog' scenario. Now if you sealed off the mains, then the TL plus floor loading would create a 6th order band-pass [BP]. Get the design/damping right and you might have something without the need for an electrical XO, but this will be no trivial pursuit.
GM
Old 12th October 2011, 11:43 AM   #6
Was,nt looking for a trivial project, no fun unless it,s a challenge! What you said about the poss of no xover is exactly what im after.
Right so need a woofer to compliment that AN driver. Preferably 8" or10" and budget not exotic i,m afraid. Once sub is settled on i can work out volumes needed and get on with the case,s
Hope it,s ok linking to an image on another site, could,nt copy/paste specs.
Any input is appreciated. Not built any speakers for 20 years so am right out of the loop and have a big learning curve ahead.
Thanks guys, looking forward to more input.
Old 12th October 2011, 05:48 PM   #7
PJN is offline PJN  United States
I think that there was a project some years back where someone built a omni speaker using the 8" Pioneer full range driver in an tall octaganal enclosure. Try searching for it, it might give you some insights into your new build.
PJN
Thoughts on my isobaric "TL/Horn"box design: TheBaronGroog Subwoofers 3 31st August 2011 04:54 PM
4-way Active (3+1 way) TL 15" 8" 3" 1" cka3o4nuk Multi-Way 44 25th April 2011 02:26 PM
Anyone remember or have details "Practical Wireless Europa" integrated amplifier. Mooly Solid State 4 25th April 2010 05:59 PM
FS: Seas Excel TL Home Towers "Thors" Houston/Austin pickup only kappa546 Swap Meet 15 1st September 2008 03:12 PM
ML-TL question: Meaning of dip at "Woofer and Terminus Far Field SPL" JC Fardo Multi-Way 3 14th February 2004 01:20 PM
Page generated in 0.09676 seconds (76.21% PHP - 23.79% MySQL) with 10 queries
