I picked up a pair of Electro Voice SP 15's - Page 2 - diyAudio
Old 26th November 2012, 07:35 PM   #11
Hello Freddi, nice to read your post again here......
first i removed the brillance circuit that is 0,20mH and a 2,4uF those are in series with the wipper of the brillance pot connected to one side of the 2,4uF
The pot is 100ohms 5 watts.both sides of the pot are on the plus and minus of the SP15.
That done i knew i used the SP15 as a two way design.
My tweeter is a LPG 26N neodium magnet 92 dB/w/m eff.
Since the SP15 really shoouted stronger, i did use a series resistance with the SP15.
That plays two things, changes the QTS actually raises it, it's an Ok thing for open baffle and trim down efficiency to match my tweeter.
I know that the other way reversed, you trim or pad a tweeter/midrange to match an inefficient woofer, but here it proved to be the solution.
Ididn't wanted to have a 10cu.ft. boxes-i had Altec's 18's in the past- but use a very good driver in OB.
Franly it's great and a fraction of the cost of my PHY-HP.......
Crossovers had to be 6db/oct. for minimum phase error, so i did spread the filter points a bit.
SP15 low cut at 1KHz, and tweeter is 4KHz.
Yeah i see people read this and have questions, in fact the SP15 with the wizzer even so responded quite well to 2KHz.....That make some experimenting with inductors and caps a challenged.
With 845 SET's amps on 8 ohms taps it's so magical! This amp is sensitive to complex impedances curves.
Updated Dynaco ST70 really sings.
I also uses a Sonic Frontiers power2 at 130 watts per channel, only to have more control.
Low freq, responses go low about 45Hz.
With a good matched sub you have a great system.
Electro-voice SP-12B 12" full range drivers analogKidA Swap Meet 0 2nd October 2011 07:50 PM
Electro Voice SP12B's 503Timber Swap Meet 0 25th August 2011 10:49 PM
Up for Auction - Pair of Electro Voice EVM-12L wboyd Swap Meet 0 26th August 2009 09:39 PM
FREE Pair of Electro-Voice MC12A's HTRookie Swap Meet 1 29th February 2008 08:35 AM
Electro Voice dirtyk777 Subwoofers 1 29th July 2007 12:02 PM
Copyright 1999-2017 diyAudio
