Novice build of Silbury - Page 3 - diyAudio
Old 11th October 2011, 07:55 PM   #21
frugal-phile(tm)
planet10's Avatar
Originally Posted by sreten View Post
Hi, sorry but thats pure marketing speak tosh, it does nothing of the sort in any effective sense, rgds, sreten.
Ron Clarke does nothing without a reason. He has some very advanced proprietary modeling tools* that allow him to actually see this expansion. Then proven in practise.
*(Based on tools that keep billions of litres of fluid in their pipes)
The expansion is allegedly "Hypex" whatever than means, but properly tapered expansions will work better.
The design is simplistic, with parallel sections, it could easily be modified for 3 section tapers, YMMV.
And with 3 tapered sections it would not work as well. The discontinuities & expansions followed by reductions act as low pass filters that keep the higher frequencies out of the mouth output. Work pioneered by Harry Olson, and refined by Tetsuo Nagaoka.
Theory is fine, but the proof is in the pudding.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 11th October 2011, 08:48 PM   #22
mp9 is offline mp9  United States
Originally Posted by highfieldrebel View Post
There's a couple of deadspaces, I used dried sand to fill these.
I'm working on the Victor (similar design), and plan to spray a expandable insulation foam in the void behind the compression chamber etc., to keep the weight down. Any reason why i shouldn't?
Old 11th October 2011, 09:04 PM   #23
chrisb is online now chrisb  Canada
other than it's a lot harder to remove than granular materials if you get undesirable artifacts, probably not
... so, not as easy at it sounds, this letting go thing
Old 11th October 2011, 09:08 PM   #24
well then, care to share your design portfolio or build gallery?
Old 11th October 2011, 09:38 PM   #25
...what are the chances of that happening?
Old 11th October 2011, 10:59 PM   #26
uncertain - hence the "if" not "when" - seriously, has anyone experienced grief with this technique, or had opportunity to compare to sand / kitty litter, etc?
Old 12th October 2011, 12:33 AM   #27
What would you do if you were unhappy with the granular material? Drill and try to shake out?
Old 12th October 2011, 12:43 AM   #28
I'll usually install the input terminal cup at that location, or include a large enough recessed aluminum plate to permit access, and the last few grains would need a vacuum.
Old 12th October 2011, 01:01 AM   #29
OK capisco
Old 12th October 2011, 03:52 AM   #30
This large of a void space isn't something i ever dealt with in a build. Honestly i didn't even know expandable foam was considered a technique used, let alone a acceptable one. I'll infer it is since you asked about experiencing grief with it, just not a tech you've used
Novice speaker build bull041161 Multi-Way 15 1st October 2009 07:52 PM
Could anyone help a novice? sunnycue Full Range 8 4th August 2006 06:45 AM
Novice in need of help skiermurph Solid State 2 22nd December 2004 02:52 AM
Copyright 1999-2017 diyAudio
