Old 10th October 2011, 03:18 PM   #1
Default Bigger is Better help ?
Have any of you guys tried to floor load these
placing the opening at the bottom front of the enclosure.
In my thinking it would increase bass and allow to pull them
away from corners and out into the room for better imaging as well.
any thoughts
Old 10th October 2011, 06:01 PM   #2
zman01 is offline zman01  Bangladesh
There is already something called the Inverted BiB or iBIBk:
p10 hifi | Box Library / Fostex
Old 10th October 2011, 06:15 PM   #3
I should have been more specific.
that is for 4 inch driver,
I am looking for inverted enclosure for 8 inch driver
Old 10th October 2011, 09:24 PM   #4
GM is offline GM  United States
GM's Avatar
FWIW, all my large pipe horns [aka BIB now] were floor loaded 12" -15" wide BW woofers, so choose whatever tuning you think will work well and either use the mouth/floor gap to fine tune them or use the theoretically optimum reflex vent area = Sd regardless of base area [Sm] as I did.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Is bigger better? GregH2 Solid State 28 4th August 2010 03:33 AM
Bigger is Better...as a 2-way? Spasticteapot Multi-Way 0 24th November 2006 08:06 PM
Characters getting bigger and bigger Elso Kwak Everything Else 11 31st May 2003 10:43 PM
Is bigger better? Pete Fleming Solid State 8 29th September 2001 01:54 PM
Page generated in 0.08581 seconds (75.46% PHP - 24.54% MySQL) with 10 queries
