Hello all
I am planning, making some speakers, for out kitchen room. The room is approx. 6x4 meters (24square), and i need speakers to hang on the corners (at the wall). I am planning, making them active with some buildin LM amp. e.g. http://www.national.com/profile/snip.cgi/openDS=LM1875 -Perhaps with a bass boost circuit. But thats not important here. What i really need, is some guidance of what to choose, and what to build. The speakers must be cheap (Well around 75-100$ for a pair of raw drivers), as i am not intend to use a lot of money on this projekt. -I was thinking of some 5-8" fullranger in a diy chassis. Any input's. ??? Jesper.
DIYAudio crazy.... LeachAmp, PearlPhono, Pumpkin, F4 DualMono, DDDac, HalfChang Spk., LinuxAudio, Squeezebox substitute, Drek inductorloaded pre-amp. |
#2 |
The Micro-Tower HalfTower wallMount for Mark Audio CHR-70?
http://homepage.mac.com/tlinespeaker...aps-150909.pdf |
#3 |
frugal-phile(tm)
I would recommend CHR as well. One of the reasons being that the metal cone won't absorb cooking smells.
It can be made to work in boxes from 5litre sealed to 9 litre vented, and then things like the ML-TLs (like the halfTower) dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#4 |
Why would it matter if the cone absorbed cooking smells? Does it matter if the surround absorbs it instead?
![]() I immediately saved that PDF-file, great stuff!
Bart |
#5 | |
frugal-phile(tm)
dave
#6 | ||
Jesper.
#7 | |
Kitchen smoke/oil will travel quite far, depending on what/how you cook, of course
I am glad I don't know what jitter is, otherwise I might hear it. |
#8 |
Wouldn't puzzlecoat help that?
#9 |
I've been looking into this myself because my new microTowers (EL70) are in my living room which is directly adjacent to my kitchen (typical bungalow layout) and I am quite concerned about smoke, oils, dust, etc. getting onto the beautiful paper cones of the EL70s, doubly so because 2 of my four drivers are on the top surface of my towers and these oils settle readily on horizontal surfaces.
Just last night my wife accidentally burned some oil when she was making fried tofu and the kitchen/living room area filled with oily smoke. I panicked and put a sheet of Kleenex on each of the top-mounted drivers, but I'd really rather not have to worry about this. In hindsight, I should have bought metal, poly, or cerametallic coned drivers, but that is not the case so now I am in search of an appropriate paper cone treatment. I read about "Puzzlecoat" and Scotchguard, and also about diluting white (PVA) glue 10:1 and painting it on. I hope someone (dave?
I am glad I don't know what jitter is, otherwise I might hear it. Last edited by cogitech; 4th October 2011 at 08:25 PM. |
#10 |
Perhaps I should ask the question in another way.
Dave, would your EL70en (EnABLed) drivers be more resilient in a kitchen than stock EL70s? If so, what do you use, or recommend using, as a coating? EDIT: Never mind, Dave. I see your answer here http://www.t-linespeakers.org/design/tweeks.html I appears as though my EL70s might end up sounding better and be more resilient to environmental factors if I treat them in this way.
I am glad I don't know what jitter is, otherwise I might hear it. Last edited by cogitech; 4th October 2011 at 08:46 PM. |
| choosing the right speakers and cab for me! help! | crother316 | PA Systems | 2 | 23rd August 2011 10:17 PM |
| I need Everyday Electronic article | Zen Mod | Solid State | 0 | 16th January 2009 09:38 PM |
| Choosing speakers for Death of Zen | starbase218 | Multi-Way | 12 | 30th January 2007 02:56 PM |
| speakers choosing | ulolin | Car Audio | 4 | 19th November 2005 10:27 PM |
| Help on choosing an old Goodmans speakers | beta_sound | Multi-Way | 5 | 16th May 2004 07:58 PM |
| Page generated in 0.12990 seconds (79.47% PHP - 20.53% MySQL) with 11 queries |
