CSS EL70
CSS EL70
Old 27th September 2011, 02:11 PM   #31
taisho_daniel is offline taisho_daniel  Philippines
Originally Posted by jimbro View Post
I'd crossover at 200 hz and see if I can get satisfactory performance using the Yamaha bass management. If not and I have to go with 'real' bi-amping, the xover would be around 300. I do occasionally listen loud but in a small room. Knowing me like I do I'll probably end up with both el70s and alpair6ps eventually. Need to keep watch though because, if I read Mark correctly, the el70s are limited to stock on hand and more won't be made without substantial requests.
Hmmm ... wasn't Mark's reply at one of the other threads targeted more towards the No 3 Tweeter and No 6 Woofer rather than the EL70s? (ERT26 and EL166 in CSS nomenclature)
Old 27th September 2011, 02:14 PM   #32
jimbro is offline jimbro  United States
CSS EL70
Originally Posted by tuxedocivic View Post
Where did you read that? That would be a shame.
On the Mark Audio forum in his thread on current drivers he replied to my question about el166s and said he listed the el70 as a current driver because CSS had some in stock which I took to mean he wasn't going to make more. May need to ask him directly about it. Hope I'm wrong.
Old 27th September 2011, 02:17 PM   #33
GM is offline GM  United States
GM's Avatar
Originally Posted by Cal Weldon View Post
Not here. I guess Dave's treatment tames that tiger. I find them a little reserved at the top.
Seems reasonable. Not having the patience or steady hand these days to attempt such fine detail, I resorted to my tried n' true 'shotgun' approach of masking the DC and 'shooting' them with a controlled pattern of Dammar. I imagine a bit flatter in response overall compared to yours, but even with the DC and outer rim area untreated, still could use an ultrasonic tweeter for some top end 'air'. Not that I can hear it anymore per se.........
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 27th September 2011, 04:33 PM   #34
CSS EL70
Sorry to hear that GM but your avatar might be a clue :-) Try this trick I learned from my old piano tuning days. About a hour before your listening session put in some foam earplugs. When you remove them you'll hear highs like you haven't heard in years - for a while at least. Not sure why but it works for me.
Old 27th September 2011, 04:35 PM   #35
chrisb is offline chrisb
The EL70 was an OEM design for Bob Reimer/CS, and yes, unless he (Bob) has a change of mind, will be limited to his remaining stock. Even without the EnABL treatment, it's a helluva performer - IMO, close to what I'd imagine a budget paper Alpair7 might be.
Mark's design goals for the CHP70.2 were certainly different than for the EL70, and having recently heard both, I think it's fair to say that he achieved them.
In addition to ongoing efforts to streamline production steps and enhance cost efficiencies, as per a couple of comments in this sticky post
http://www.diyaudio.com/forums/marka...pt-2011-a.html
Mark has already and might yet again consider requests for revisions to tailoring driver's response. Of course he'd need to be confident of marketability of any of these customized versions.
The Alpair6P is very very nice, and of all the MA papers would be my candidate for mid tweet for a FAST.
like my mind, this space intentionally blank
Old 27th September 2011, 06:24 PM   #36
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
CSS EL70
Originally Posted by chrisb View Post
The EL70 was an OEM design for Bob Reimer/CSS, and yes, unless he (Bob) has a change of mind, will be limited to his remaining stock. Even without the EnABL treatment, it's a helluva performer - IMO, close to what I'd imagine a budget paper Alpair7 might be.
Bob still has >200 units, i have about 60, and there are units at distribs in Europe & Oz. So unless there is a really big run, they should be around for awhile.
I personally, would like to see Mark put back the highs for the next CHPs. Or, if a consortium could be put together to cover a 1,000 drivers there is likely nothing to stop a resurrection with or without Bob's help. EL70 the Next Generation.
Ryan, I have a road kit of milliSize for comparing EL70 vrs CHP70 (stock), after Kyle has them would you like to lend your ears? Anyone else on the islamd is also welcome to borrow the comparoKit.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 27th September 2011, 06:33 PM   #37
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
CSS EL70
Agreed.
Understood.
Compensation.
planet10 needs your help:
Let's help Ruth and Dave
Old 27th September 2011, 07:33 PM   #38
vinylkid58 is offline vinylkid58  Canada
vinylkid58's Avatar
I was thinking an A6P + EL166 (single) could be quite good in an average size room, given the incredible bass output of the MTM style EL-166 box.
jeff
Old 28th September 2011, 02:00 PM   #39
GM's Avatar
LOL! Thanks for the thought, but that avatar doesn't offer even a clue to what I've subjected my hearing to over the decades. FWIW though, I got my tinnitus from having my ears drained of fluid repeatedly in various unpleasant ways between around age 18 mos - 5 yrs old, so I've never known 'silent' hearing and was a teen before I knew it wasn’t normal.
Works for me. Others I’ve shared it with also. It’s a trick I learned from a neurosurgeon cousin back in the ‘70s to initially help me get to sleep. Combined with sleeping on an incline and taking an aspirin with a tumbler full of water whenever I lay down to rest for any length of time, it temporarily quells most of the ‘roar’.
The downside to this trick though is that during the few years of the Atlanta DIY Meets, the typically flat to up-tilted HF response of two and three-way cone/dome designs had me usually exiting the room post haste, presumably due to me not being used to such ‘shrillness’, though the ribbon Jim Griffin used in his little Jordan monitor was smooth at modest SPL and there was a two-way with a Vifa aluminum domed tweeter [historically, I can’t stand Vifa drivers] that sounded as smooth as Altec 1” compression drivers, just a lot less dynamic/efficient of course. Unfortunately, I’ve lost the model number, so no clue if it’s still available or of the same specs/quality.
GM
Old 28th September 2011, 02:56 PM   #40
CSS EL70
That sounds just awful and would drive me crazier. I love Altecs. Voice of the Theater indeed. If you have em you gotta crank em.
CSS EL70Hide this!Advertise here!
Attenuating the CSS EL70 motosapien Full Range 2 25th June 2011 08:20 AM
My brief CSS EL70 review 60ndown Full Range 5 28th May 2011 12:31 AM
CSS FR125S, Alpair 7 & CSS EL70? Monte Verdi Full Range 6 29th June 2010 08:51 PM
Introducing The new CSS EL70 CSS/XBL CSS 41 19th April 2010 09:23 PM
