Stainless Steel CHR-70
Old 16th September 2011, 02:58 PM   #1
StevenZ is offline StevenZ  United States
Default Stainless Steel CHR-70
Hey guys, just thought I'd show y'all a build I did for a friend of mine. He had a pair of CHR-70's laying around and requested an all black cabinet. Instead I gave him a real treat by using my 13 ply void free birch core plywood and wrapped it in 1/32" stainless steel; internal volume is 5 liters sealed. They sound phenomenal for being entry level drivers. It took 4 hours from start to finish, which included programming the CNC router, building, veneering, and mounting everything. Enjoy!
-StevenZ
Old 16th September 2011, 04:44 PM   #2
borispm is offline borispm  Hong Kong
borispm's Avatar
Send a message via MSN to borispm
Wow, damn! That's cool! I wish I have the skills to make something like this!
How do they sound? How thick's the plywood?
Old 16th September 2011, 05:23 PM   #3
Thanks Boris! They sound amazing with pinpoint imaging and razor sharp detail. The plywood is a true 3/4" (.750 with my Mitutoyo caliper). Realistically though, anyone can do it. A hand router, a circle jig, and a table saw is all you need. I find building speakers to be greatly rewarding and a true passion of mine in sharing hifi audio with family and friends. The best part is watching a huge smile appear on the face of the person who the speakers were built for as they look around the room at the huge sound stage cast against the back wall and floating into the room.
-Steven
Old 16th September 2011, 07:55 PM   #4
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Stunning. The stands now need to be brought to the same level
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 16th September 2011, 08:01 PM   #5
Hahaha! Thanks Dave. Yeah, the stands need to be burned. They were a 15 minute job to test out different height positions. Hopefully I can have my solid surface buddy throw together a nice set some time soon.
Old 17th September 2011, 12:15 AM   #6
naturallmystic is offline naturallmystic  United States
Those are beautiful StevenZ, glad they sound great too.
How did you attach the stainless to the wood substrate? I assume glue but what glue did you use. Also how did you cut the stainless? Though 1/32 is thin I can't imagine plunging a router into stainless.
Scott aka Naturallmystic
Old 17th September 2011, 12:33 AM   #7
Scott, I used Wilsonart professional grade red contact adhesive (I have a 55 gallon drum and dedicated spray system attached). My technique is to cut pieces about 3/4" larger than the surface, then use a hand router with flush cut with a laminate bit like this (C1455 Solid Carbide Flush Trim Laminate Bit, 1/4" Shank). Be careful though because the stainless steel wears down the bit pretty quickly so you must move fast or else it'll suck up against the adjacent surface and dent it. So a perfectly smooth cut isn't going to happen unless on each pass you raise the height of your base to always have a sharp edge. You'll need to keep the protective film on during the entire laminating process, all the way until you get every side laid and you're ready to clean off the glue. Peel the plastic off, wipe with lacquer thinner until clean, then file the edges with a laminate file. Filing takes work and experience so practice on a test piece before you muck up your finished work. When you're satisfied that you won't cut yourself on the edges, go ahead and clean it up with some stainless steel wipes or solution, and voila. You've got yourself a spiffy little speaker.
Keep in mind a sheet of stainless steel like this can cost up to $350 for a 4' x 8' sheet and can only come shipped on a flat pallet (depending on quantity ordered). It may not be the most cost effective covering for an enclosure, but done right it sure comes out pretty.
-Steven
Old 17th September 2011, 10:48 PM   #8
kristleifur is offline kristleifur  Iceland
Gorgeous.
Stainless Steel CHR-70Hide this!Advertise here!
Stainless Steel Chassis Polishing wrenchone Construction Tips 10 10th June 2011 10:49 PM
stainless steel for enclosure tangmonster Construction Tips 20 13th November 2010 08:33 AM
Building in Stainless steel and timber! pheonix358 Multi-Way 25 9th December 2009 03:01 AM
Stainless Steel Death of Zen pre amp DocLorren Solid State 10 29th October 2006 08:31 PM
working with stainless steel jteef Everything Else 10 5th October 2002 07:02 AM
