Old 15th September 2011, 11:43 PM   #1
mondogenerator's Avatar
Default 'New' extended range drivers...any thoughts?
cruising through the usual speaker haunts i came across these:
Visaton - Lautsprecher und Zubehör, Loudspeakers and Accessories
now up until now i havent thought much of visatons fullrange drivers, but these dont look altogether bad.
Has anyone used these? im still searching for a source to buy these that will deliver to the UK...maybe i should try lautsphrecher.de again....
yes I admit it, im starting to get addicted to the mini drivers.
Dave(p10) i blame it all on you
Im starting to think its gone beyond a hobby, a wardrobe full of drivers instead of clothes...
Old 16th September 2011, 06:50 AM   #2
chris661's Avatar
I'd try this - no rising response there.
I've tried the FRS8 and the M version, (the latter in a FAST), both did reasonably well, but struggled with higher volumes - this problem was particularly apparent on the M version - 300Hz 2nd order wasn't enough to stop it going into nasty cone break-up early on.
Sounded detailed, etc etc - all you'd expect from such a tiny cone.
Chris
Old 16th September 2011, 07:03 AM   #3
frugal-phile(tm)
planet10's Avatar
You are most welcome...
the 1st one looks interesting, but i am wary of neo motors ATM. I was going to do the FR88ex, bought 24 of them, then the price close to doubled (due to Chinese hoarding) taking them out of contention... turned out to be a good excuse todo a line array experiment.
The 2" one is kinda cute too. Only Visaton experience i've had is the B200 -- distribution in North America is spotty.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 16th September 2011, 07:38 AM   #4
@chris: thanks! I had looked at the sc8n before. The lack of rising response is an upside, but theres some mid to hf wiggles that arent terrible, but enough to make me hesitate.
@dave: haha! Im just another amateur looking for the wideband/fullrange holy grail: flat as possible over the largest bandwidth possible. I agree, the 1st driver seems the best. Rising response is almost trivial its so gradual, the whole NeFeB story is the real bugbear. The little 2"er isnt bad either.
Cheers guys. Its nice to know i havent lost it entirely!
Old 17th September 2011, 04:34 AM   #5
Then there's these.
Considering that you can soften the spider of these in about 2 minutes per driver to get Fs into the 50-60 hz range and they have an underhung VC and 4-5 mm Xmax, I think they are an unparalleled deal at Madisound's price.
Old 17th September 2011, 04:37 AM   #6
49 - for the 16th time
c2cthomas's Avatar
Originally Posted by thoriated View Post
Then there's these.
Considering that you can soften the spider of these in about 2 minutes per driver to get Fs into the 50-60 hz range and they have an underhung VC and 5mm Xmax, I think they are an unparalleled deal at Madisound's price.
80db - not for me thanks
"You can't always get what you want" K. Richards/M. Jagger *** "Next time I will know some things better" Zen Mod
Old 17th September 2011, 08:02 AM   #7
im not a fan of the aurasound ones either....response looks nice but 80dB/W?!?! 84-90dB is better, even the least efficient ones i have use are 83dB and the w2-800sl around 87dB
Old 17th September 2011, 08:14 AM   #8
frugal-phile(tm)
planet10's Avatar
Hoffman's iron law. You probably won't find a 3" that goes lower than the Aura,
dave
Old 17th September 2011, 08:37 AM   #9
borispm is offline borispm  Hong Kong
borispm's Avatar
Send a message via MSN to borispm
The efficiency of those Aura drivers are not that terrible, especially if you use more than one driver. They don't need much BSC and that's a plus side.
Tangband often overrates its drivers' sensitivity by 3dB, so I'm not sure if you will really find the sensitivity of those Aura drivers as low as you expected.
Old 17th September 2011, 08:39 AM   #10
borispm's Avatar
And yes, I suspect the only driver of this size that's going to go deeper than the Aura is Audience A3...
Your next extended range driver? Scan Speak Discovery 10F/4424G00 ScottG Full Range 54 18th August 2010 09:40 PM
Extended range measurement mics and pre-amps percy Multi-Way 1 17th November 2007 01:55 AM
Extended range tweeters and headphones percy Multi-Way 0 17th November 2007 12:04 AM
Which 2" extended range from Tang Band? nrgy Multi-Way 9 29th September 2004 07:50 PM
What to do with these OLD 10" extended range drivers? swirv Multi-Way 9 23rd July 2004 07:27 PM
Page generated in 0.11296 seconds (80.16% PHP - 19.84% MySQL) with 10 queries
