Location: Mississippi, where good music comes from, or used to anyway
I'm looking at making a 5.1 system using the Alpair 10.2 for each of the five channels or maybe subbing two Alpair 7's for the rears. I am faced with some space restrictions. The rear speakers will have to be mounted about 7 feet up in a 2'x1 area and my center channel can't be too large. I am looking at using the pensil designs for my left and right channels. my center channel will need to go on top of my entertainment system which has a 48" x 18" top and it can't be more than 1' tall. Any help on enclosure ideas would be greatly appreciated.
Suffice it to say that I have a very small living room. |
#2 | |
How large is the room? Considering the fact that even using 10.2s would still require separate woofer(s) for the .1 channel, you might want to consider downsizing to the Alpair 7 for the front row, and perhaps even A6M for the rear. You may well have plenty of floor space for the Pensil 10 enclosures, but the restriction on the center channel enclosure could be an issue. My own HT system is in a room approx 340 sq ft (listening position at approx 60% long dimension), and the complement described above provides quite adequate for SPLs ( I probably should measure for posterity sake) The center channel enclosure for the Alp 7 measures approx 7 1/4" H x 18" W x 8" D - small enough that it's temporarily been used (for the past 3 or 4 months) as a stand for the flatscreen TV - this keeps the acoustic center more aligned with the drivers in the Pensil-7s . Enclosures for rear surrounds and optional front height for the A6M can be pretty tiny - as small as 2 or so liters sealed. Mine were compound angled for installation in upper corner - I'd probably do it differently next time.
you don't really believe everything you think, do you? community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi |
#3 |
I guess I should have mentioned that I have a subwoofer to handle the bottom end. I have space on top of my entertainment center that could theoretically accommodate and enclosure "12 tall x "48 wide x "18 deep. Hope that helps.
It looks like I will have 3 of the 10.2's and two of the 7's. |
#4 | |
It's generally taken for granted that any 5 or 7.1 surround system incorporates (at least one) sub - two or more smaller units for distributed bass works must better. Not to beat a dead horse, but how large is the room? It could well be that the 10.2 is larger than you'd need, but if you want to pursue that, there must be a drawing for small center enclosure on someone's sketchpad. Remember that it needn't dig very deep - as low as 80 or so would be fine, so a small sealed or resistively vented could work fine, including something like the attached. http://homepage.mac.com/tlinespeaker...map-080211.pdf . In my own system with 7s in front row, I settled on 110 as XO to the LFE channel, and am still fiddling with XO for the surrounds.
you don't really believe everything you think, do you? community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi Last edited by chrisb; 15th September 2011 at 09:21 PM. |
#5 |
The room is roughly 15' x 18'. I want to go ahead with the 10.2 setup since there is a very good chance that we will be moving to another larger home in the near future. I have seen the pdf that you linked and I've been pouring over the plans on the planet 10 site. Hope that helps.
| Steven's Alpair 10.2 Pensil Build Log | StevenZ | Markaudio | 147 | 21st December 2011 10:28 PM |
| Need Complete Home Theater EL70/CHR-70/Alpair 7 | cbro | Full Range | 32 | 1st January 2011 05:25 PM |
| Alpair 10 wide bass driver and Alpair 10 Fullrange | _henry_ | Full Range | 71 | 15th March 2009 11:37 AM |
| Help me build a Home Theater subwoofer | rocko1290 | Subwoofers | 3 | 1st September 2006 08:53 PM |
| i want to build a sub for my home theater | michelevit | Subwoofers | 13 | 20th October 2005 05:03 AM |
| Page generated in 0.09713 seconds (77.22% PHP - 22.78% MySQL) with 10 queries |
