Old 9th September 2011, 12:15 AM   #1
Default Help with notch filter for Beta 12LTA?
Can any of you guys recommend a good notch filter
to tame the peaks of this driver.
Old 9th September 2011, 03:50 AM   #2
Up_3dB is offline Up_3dB  United States
I recommend using a 31-band graphic equalizer (GEQ). I have some 12LTA cabs and a 15-band GEQ, and it sounds really good, but a 31-band GEQ would allow even better 'taming' of the peaks AND valleys.
Old 9th September 2011, 04:02 AM   #3
Pano is offline Pano  United States
Pano's Avatar
Have a look at what is used on the Hammer Dynamic, it's basically a 12LTA.
Hammer Dynamics Super 12 Loudspeaker Kit
There are other versions of this filter. Also look for the Afterburner project.
Old 9th September 2011, 07:04 AM   #4
norman bates's Avatar
try asking over at the full range driver forum.
Fullrangedriver Forum
Norman
Old 9th September 2011, 08:14 AM   #5
freddi is offline freddi  United States
freddi's Avatar
I'm not sure if its "that peaky" on-axis - IIRC the afterburner notch values didn't do much. Your best bet is to mount the speaker in desired enclosure or baffle, measure in real time and do some adjustments to the LCR trap
here's 3 cases outdoors where I've measured that speaker - the last one shows on and ~20 degree off axis where a typical for fullrange speaker hole appears and a peak
12LTA in a little K12 Karlson enclosure on and 45 off at several mic heights
12LTA in an Aristocrat (1953 EV/klipsch design)
12LTA mounted in the top right corner of an inappropriately tuned
4.6 cubic foot tapered pipe
12LTA would probably work very nice in a Karlson enclosure with ~2.2 cubic foot rear chamber and about half that front. A slotted waveguide tube tweeter would be nice.
although there's not much motor on 12LTA and can be weak on dynamics, it did an admirable job with.Danley's Harley recording in the Karlson 12. That would kill AN Super 10 in a reflex - the cone with AN10 jumped like crazy in a 70liter/41Hz reflex trying to play that Harley. AN10's cone excursion in a Karlson coupler is generally under control and will do useful work.
Old 9th September 2011, 02:20 PM   #6
Godzilla's Avatar
Beta 12LTA in a 3cf box - port size
I'd just cut out the dustcap and add a phase plug... done. That's how i enjoy them... i love the EQ idea but i don't have any desire to run one thru my tube amps. I would if i were using solid state tho. I'd imagine that if one were willing to use the EQ you'd have the most amount of control of the overall balance of sound.
Old 9th September 2011, 08:08 PM   #7
Thanks for all the input guys.
Old 10th September 2011, 12:06 PM   #8
godzilla, what'd ya use as a phase plug ?
Like Home Depot ? and what size so anyone can go in and buy one....
Norman
Old 10th September 2011, 01:02 PM   #9
just another
wintermute's Avatar
I found this wikipedia page invaluable for making notch filters. Takes the guess work out of it!
RLC circuit - Wikipedia, the free encyclopedia
go to the parallel RLC section (but it helps to read the preceding stuff as well.
If you are like me and shy away from maths, it looks intimidating but if you can get your head around at least the Q formula and the Wo formula you should be able to work out a filter suitable for your desired frequency. swapping the values for C and L will change the q (without changing the centre frequency) and the resistor determines the amount of cut.
Choose a value for C or L and the frequency and then work out what the value for the unknown component (L if you chose C) is. adjust until you get usable values and the desired Q.
I found this to be a much better starting point for simulation (very close to the desired frequency) than the methods I'd found in my speaker books.
edit: using the Wo formula and the 8.5uF and 0.65mH in the notch filter in pano's post gives a notch frequency of around 13,450 Hz That seems a bit on the high side, I think the formula has been changed to radians (since I last used it), so you also need to divide by 2pi which gives about 2140Hz which seems more reasonable.
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Last edited by wintermute; 10th September 2011 at 01:20 PM. Reason: replaced Fb with Wo forumula
Old 11th September 2011, 01:20 AM   #10
I'd use a pot to determine the resistors values, then replace with a fixed one. Remember that the impedance usually increases as the freq goes up, so you may need a 16ohm resistor to cut the peak by 6db using an 8ohm driver.
F = 1 / (2 x Pi x L x C)
so you multiply 2 x Pi x .4 (the inductance) x 10^-3 x 4 (the uF) x 10^-6
then with the result, press the 1/X key, now you have the notch frequency.
It's simple.
Norman
Beta 12LTA in a 3cf box - port size Godzilla Full Range 309 21st February 2012 01:02 PM
Eminence beta-12lta on OB? grantnsw Multi-Way 0 8th January 2010 02:38 PM
Phase plug for Beta 12lta JimW Full Range 1 21st April 2005 12:07 PM
New Project Beta 12LTA Fostex FT17H in a TQWT MIKET Multi-Way 27 23rd March 2004 04:14 PM
Eminence Beta 12lta Glenn Swiderski Multi-Way 5 9th December 2003 01:31 PM
Page generated in 0.11312 seconds (78.26% PHP - 21.74% MySQL) with 10 queries
