Madisound BK12m
Madisound BK12m
Old 22nd December 2011, 09:59 PM   #41
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Madisound BK12m
Originally Posted by ssportclay View Post
I have heard rumors that people actually burn these Fostex enclosures to keep warm whilst listening to their ipods with very cheap headphones.
The Fostex designs for the FE126 are particularily bad... the TL/BR hybrid has you thinking about a pair of woofers right off the bat (in which case a small sealed makes WAY more sense, and the BR has been described as a "cruel joke"
The fires are usually big & outdoors. They need to be really hot to burn up the glues.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 22nd December 2011, 10:53 PM   #42
Lefty78 is offline Lefty78  United States
I have a corner style Mantle in a small living room approx 15x15.
If i dont have clear corners to place MK3's in, would the BK12 be a better suit?
What are the advantages of the BK12 over the MK3 design for the same FE126en speaker?
(Using a miniwatt amp)
Walt
Old 30th December 2011, 02:19 PM   #43
ssportclay is offline ssportclay  United States
Walt
The BK-12m should be less room placement sensitive than the FHMK3 and might prove to be a better back yard picnic speaker where no walls or corners are available. I suppose a scaled up a redesigned BK-12m for the FE166En might prove practical. Very few good enclosures exist for this driver. There is the Victor,(kind of tall), and the Austin,(kind of complicated).
Old 30th December 2011, 10:43 PM   #44
frugal-phile(tm)
planet10's Avatar
Madisound BK12m
It exists, but not released.
dave
Old 31st December 2011, 12:24 AM   #45
chrisb is offline chrisb
now that's cute -
as well, the FH3 was intentionally designed with latitude for a range of small wide band drivers, while the BK12 was optimized specifically for the FE126En
Yes, if you have the space, Victor works very well, but is certainly more obtrusive than either the FH3 or BK12
like my mind, this space intentionally blank
Old 12th January 2012, 08:08 PM   #46
If i were to put a rounded edge on the mouth opening of the horn, for cosmetics, would this affect sound in any noticable way?
I was thinking og putting a router to all 4 sides of the opening before the box goes together.
Old 12th January 2012, 08:38 PM   #47
frugal-phile(tm)
planet10's Avatar
Madisound BK12m
How would you round the mouth?
dave
Old 12th January 2012, 08:58 PM   #48
Router with round over bit before putting it together.
Old 12th January 2012, 09:04 PM   #49
I'm thinking he means using a small round-over bit on the 4 sections of sides, bottom and front baffle panel that outline the mouth opening.
probably not much noticeable affect would be my intuition
Old 12th January 2012, 09:14 PM   #50
frugal-phile(tm)
planet10's Avatar
Madisound BK12m
At that sizes effects will be pretty much cosmetic only. Go ahead
dave
Madisound BK12mHide this!Advertise here!
Madisound off-line? m12ax7 Multi-Way 45 22nd October 2010 03:54 PM
MarkAudio now at Madisound Tom V Full Range 25 6th July 2010 07:14 PM
Madisound.com xtremekustomz Multi-Way 9 12th July 2007 07:52 PM
Help with ar.com kit from madisound Bobhof Multi-Way 15 24th April 2006 10:28 AM
I want madisound to update their 5th element Everything Else 3 26th March 2004 10:35 AM
