Madisound BK12m
Madisound BK12m
Old 14th July 2013, 04:34 AM   #151
acurus is offline acurus  United States
acurus's Avatar
Thanks guys ! It took me more than I anticipated to build them since my cabinet making skills are pretty limited . I did not rush, took my time & followed step by step instructions .Very pleased the way they came out.
Originally Posted by OJNeg View Post
Great job! How big are those stands? I'm thinking I should make a pair myself.
These are 3" thick maple butcher blocks 10"w x 5"h.
Originally Posted by Scottmoose View Post
Those risers are attractive. Jus
t be aware you'll loose some floor-coupling. Tradeoff between that & getting the driver further on-axis with the ears for those with higher chairs.
First of all many thanks to you & everyone else who was involved designing these horns. I actually added 1" wooden isolation cone ( pics ) underneath the horns ( about 5dg tilt angle ).To support back of the speakers I used kitchen cabinets shelf brackets (pics ).
Old 15th July 2013, 10:23 AM   #152
xrk971 is offline xrk971  United States
xrk971's Avatar
Madisound BK12m
Looks really nice - great wood working skills there. I never understood why speakers sometimes have sharp spikes on the feet that will concentrate all the weight to a singularity that will either cause damage to the floor or whatever they sit on...
Old 15th July 2013, 10:44 AM   #153
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
Because some people have carpets, and spikes were originally intended to pierce these to improve stability (viz. to stop the speakers falling over whenever anybody walked past). The original purpose has become a trifle diluted over the years.
Old 18th November 2013, 04:31 AM   #154
Brian Steele is offline Brian Steele  Grenada
Originally Posted by planet10 View Post
A modern interpretation of a classic. Another flat-pak to increase diyers choice.
My apologies for digging up an old thread. I'm looking for a HornResp model of this design. Is one available?
www.diysubwoofers.org
Old 18th November 2013, 05:03 AM   #155
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Madisound BK12m
Not that i know of.The design was done with MJK (a step up from HornResp IMO) and a number of proprietory tools.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 19th November 2013, 03:00 AM   #156
dave
I might put together a model this weekend if I have the time. It looks fairly straightforward - rear-loaded horn with a damped back chamber, horn in four segments... Are there any impedance measurements of a built horn available that I can use to compare against the HornResp model?
Old 15th January 2014, 02:46 AM   #157
armalite is offline armalite  United States
any problems using mdf for this build? I know mdf is considered less resonant than coated plywood but I have a bunch of 3/4 mdf and was considering using this for all of the build except the front baffle as shown in a previous post
thanks
Old 15th January 2014, 02:54 AM   #158
frugal-phile(tm)
planet10's Avatar
Madisound BK12m
Huh?
You can build out of MDF, but the enclosure will be more coloured than if you did them out of good ply. 18mm MDF is about the same stiffness as good 12mm ply, but has much higher energy storage,
dave
Old 15th January 2014, 03:32 AM   #159
Huh?
dave
well maybe I used the wrong terminology , I meant a more "dead" ,less bright sounding cabinet ? hell, that's probably wrong also
thanks for the help
Old 15th January 2014, 05:13 PM   #160
chrisb is offline chrisb
This is one of those topics that can quickly devolve into religious / polemics territory - suffice to say that the physical characteristics of the two materials (MDF / high density plywood) are quite different, and those differences do affect the sonics.
Anecdotally, based on a few comparative builds from over 10yrs ago, I find the plywood enclosures to sound much "faster" and "musically consonant" - those are not scientific terms
kinda burnt out - taking a break
Madisound BK12mHide this!Advertise here!
Madisound off-line? m12ax7 Multi-Way 45 22nd October 2010 04:54 PM
MarkAudio now at Madisound Tom V Full Range 25 6th July 2010 08:14 PM
Madisound.com xtremekustomz Multi-Way 9 12th July 2007 08:52 PM
Help with ar.com kit from madisound Bobhof Multi-Way 15 24th April 2006 11:28 AM
I want madisound to update their 5th element Everything Else 3 26th March 2004 11:35 AM
