Old 8th September 2011, 07:14 PM   #1
sherpa is offline sherpa  United States
Default What is ideal for this driver?
I just got given a set of 5" full range drivers from radio shack minimus 4's. From what i can find these are really good drivers. What style box would work best for these? I was looking at something like the Metronome or a backloaded horn of some sort. Here the specs as best as i can tell from the internet.
5-Inch 10-ounce Speaker (400-1284) Specifications Faxback Doc. # 9718
Type: .................................................. ..... 5" Dual Cone
Nominal Impedance: ............................ 8 ohms +/- 15% @ 1V 300 Hz
Lowest Resonant Frequency: ...........................88 Hz +/- 18 Hz @ 1V
Sensitivity (SPL): ................................ 96 dB +/- 3 dB/1W @ 1m
measured at 500, 600, 700, 800 Average
Effective Frequency Band: ..................Fo to 20 KHz +/- 20 Hz @ -10dB
Input Power:
Nominal: .................................................. .... 6 Watts
Maximum: .................................................. ... 20 Watts
Magnet Size (Main): ...................................... 80 x 40 x 15 mm
Magnet Weight (Main): ............................................. 10 oz.
Buzz, Rattle etc. Test: ............................... 5V 3.12W Sine Wave
Operation Test: ...................................5V 3.12W Program Source
Frequency Response Tracer: ......................................... MLSSA
Qts: .................................................. ............... 0.8
Free Air Frequency: ................................................ 90 Hz
I run a DIYTube ST-35 and plan on building a SE 6L6 amp in the future. Also run a copy of Gary Kaufmans 6EM7 SE Direct coupled amp.
What style cabinet would work best for these drivers?
Paul
Old 9th September 2011, 05:34 PM   #2
chris661's Avatar
Given the high Fs and Qts, I wouldn't expect any series bass extension from these. I'd consider using them in a FAST system (where you use a wide-band driver and a midbass, cross over around 300Hz), as taking bass duties away will lower distortion, giving a cleaner midrange and treble.
Chris
Old 9th September 2011, 06:16 PM   #3
pjanda1 is offline pjanda1  United States
pjanda1's Avatar
To design a proper box, you'd need a VAS measurement at least. Guessing is an option, but you might not be happy with the results. If you want any significant bass, I'd ponder a BIB. Another option would be to build a box that is 1-2 cu ft, and then play with stuffing. If it is too boomy, vent the back and make it aperiodic. There will surely be QWT options, but you'll need a good set of measurements to get in the ball park, and you may well still wish for woofers.
You could do something like the Bottlehead S.E.X.y speaker, with a sealed/aperiodic. (Each FR set on top of an inexpensive subwoofer). My take would be to go open baffle. Given the size of the driver, you'd probably want to crossover fairly high. But, it depends on your maximum SPL requirements. I favor biamping with a passive crossover on top and active on the bottom. (See my forum for an example of what I did). Again, you'd be looking at crossing over higher, but you could do something very similar.
Paul
Wild Burro Audio Labs - DIY Full Range Speakers
Old 9th September 2011, 06:44 PM   #4
GM is offline GM  United States
GM's Avatar
'Guestimated' specs after break-in of a pair measured probably at least a decade ago, so no idea how accurate they are for any later variants from vendors other than Taiwan:
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 9th September 2011, 07:02 PM   #5
GM's Avatar
'Ideal'? 'Best'?
With a high output impedance, tuning to Fs is one requirement, so with such a high effective Qts [Re + Rs], a [huge] horn, aperiodic, or OB are the choices and since each amp will probably have a different impedance [as in DF, not tap, rating] will require different cab designs. That, or build whichever combination yields the largest cab net volume [Vb] and add however much series resistance is required to the others to ~ tonally balance them out.
GM
Ideal power level to suit a driver? Pbassred Multi-Way 0 27th April 2009 03:27 PM
ideal driver qts for aperiodic IB tuning Hezz Multi-Way 5 17th October 2008 04:10 PM
How much less from the ideal??? Leolabs Solid State 0 18th May 2007 02:54 AM
Ideal volume for two Vifa Pl18 driver andy2 Multi-Way 0 26th December 2005 03:24 PM
more important to match Q or box resonance when driver matching is less than ideal? wintermute Multi-Way 2 1st January 2005 07:23 AM
Page generated in 0.09670 seconds (74.05% PHP - 25.95% MySQL) with 11 queries
